E60 for Singaporeans
Old 07-20-2006, 12:13 AM
  #7201
bugaboo's Avatar
Originally Posted by lmk' post='313015' date='Jul 20 2006, 03:56 PM
i tried that too...but becareful, it may kill your OBC.
how come will kill OBC?
Old 07-20-2006, 12:20 AM
  #7202
lmk
lmk's Avatar
the stored charge in the capacitor maybe be higher than the obc voltage durig the discharge cycle. the chip can be sensitive to spikes.
Old 07-20-2006, 12:45 AM
  #7203
lmk
lmk's Avatar
deleted by lmk
Old 07-20-2006, 12:47 AM
  #7204
Zig
Zig's Avatar
My Ride: E39 525i, E60 530i, F10
I did that for my HID fog lamps. Working perfectly so far.
Old 07-20-2006, 12:52 AM
  #7205
lmk
lmk's Avatar
well, like i say, just becareful lor.
my OBC reads errors, seat belts, lights, DTC lights all blinking.... and when i remove the cap. everything's normal.
  #7206
Zig
Zig's Avatar
Maybe my OBC is already dead, that's why it didn't complain about my HID fogs.
Old 07-20-2006, 12:54 AM
  #7207
Zig
Zig's Avatar
How was your capacitor connected? What's its value? Which light output connector did you wire this capacitor?
Old 07-20-2006, 12:57 AM
  #7208
lmk
lmk's Avatar
on my red tail light.
100 microF. 15V
parallel with positive end to the positive wire.
one more thing, i used to connect my reverse sensor for my reverse cam using the reverse light. It caused some flickering on the screen. i put a capacitor across the bulb in parallel it cures the flickering problem but it blew the bulb after about 2 weeks. therefore i resort to using a relay instead.
Old 07-20-2006, 01:18 AM
  #7209
Zig
Zig's Avatar
100 microF. 15V
Interesting. the discharging path of the caps should be back to the source through the +ve wire. Maybe a smaller cap is better?
Were you using a LED bulb? The cap should be wired parallel with the LED & its series resistor, not just the LED. Otherwise, it may blow it. If you are using a filament bulb, I cannot figure out how the small charge stored in a 100μF can blow a filament bulb.
Old 07-20-2006, 01:49 AM
  #7210
lmk
lmk's Avatar
Were you using a LED bulb? The cap should be wired parallel with the LED & its series resistor, not just the LED. Otherwise, it may blow it. If you are using a filament bulb, I cannot figure out how the small charge stored in a 100?F can blow a filament bulb.
that's what i thought....but....i was wrong.
Quick Reply: E60 for Singaporeans
