E60 for Singaporeans
Old 05-17-2006, 10:39 PM
  #5121
lmk
lmk's Avatar
Originally Posted by Olivin530i' post='284028' date='May 18 2006, 02:30 PM
If I am not mistaken the catch is the 6-slot will go...... :thumbsdown:
but..... it can otherwise provide space for TV interface? Can someone give me contact for the installers please. TIA.
the 6 slot changer has to go.....but do you need it when ipod can store 10K of songs in it?
93369580 Ah Bo for video interface installation.
He is our installer.
Old 05-17-2006, 10:40 PM
  #5122
Olivin530i's Avatar
Thanks bro LMK. I guess AUX still nec?
Old 05-17-2006, 10:41 PM
  #5123
lmk
lmk's Avatar
Originally Posted by bugaboo' post='284023' date='May 18 2006, 02:21 PM
my 523i. changed oil at 10k at bvo, and 25k at pml. no top up in between.
The first time oil level low warning came only this morning just outside PML after 2 years 6 months with 43K of mileage.
Never happen before, oil change at 10K, 25K....
Old 05-17-2006, 10:43 PM
  #5124
lmk
lmk's Avatar
no prob Bro!
Aux is not needed if you have the new ipod interface. some programming needed from PML though.
Old 05-17-2006, 10:54 PM
  #5125
Olivin530i's Avatar
Originally Posted by lmk' post='284036' date='May 18 2006, 12:43 AM
no prob Bro!
Don't know if the new ipod interface will have those resistors found on the aux??
Old 05-17-2006, 11:13 PM
  #5126
BZSAB's Avatar
My Ride: E60 523iA
Originally Posted by Olivin530i' post='284032' date='May 18 2006, 02:39 PM
PML claims that it is normal to top up a little in between oil service (that's why they have this 1L in your boot after oil service) if you have 520i. I asm not sure if that is the norm for 523i, 525i or others but mine does NOT seem to need to top up.
1 liter oil oso provided for 523i. Mine is 11K and oil level is one notch lower but yet to get any message from iDrive. Was told by PML mobile service not to top up until iDrive message appears.
LMK, what's this with the Reisitor of the AUX interface? I dont think Ah Boa removed it for me! Should I get it removed?
Old 05-17-2006, 11:24 PM
  #5127
lmk
lmk's Avatar
i can't say anything yet for the new interface as i have not tried it myself.
But electronically speaking, it should not have the resistor as i assume that the interface connects directly into the low level signal then to the amplifier.
The resistor is to limit the voltage going into the amplifier at high level input preventing damages to the amp.
the capacitor acts as a filter to cut hissing noise and rumble, but contrary, it also cuts high and low frequencies. therefore what we hear is "no bass, lack of highs"
Old 05-17-2006, 11:28 PM
  #5128
lmk
lmk's Avatar
I doubt Ah Boa removed it for you. I have taught him how to remove it and my ride is the first he learned how to have the capacitor and resistor removed.
If you experienced low volume from your aux, or you need to pump up your volume to achieve reasonable loudness, then, get it remove. It sounds much better....yes, much better!
Old 05-17-2006, 11:49 PM
  #5129
BZSAB's Avatar
My Ride: E60 523iA
Yes! volume is generally softer and there are hissing and whining sound. Will call Dr. Boa to the rescue..... Thanks Bro!
Old 05-17-2006, 11:55 PM
  #5130
Stranger's Avatar
My Ride: Nothing to boast about!
If I am not wrong, the resistor ? and caps ? form a high pass filter cutting off at around 50Hz. That could explain the lack of bass. It also does the DC block in technical speak. The reason is the player may have a different biasing point compared to the ipod output stage. You don't want to have 2 different DC levels fighting each other.
My guess without them, the amp input is now sitting a higher DC which could explain the louder volume heard.
Sorry for the technical mumbo jumbo.
Personally I won't remove them. But that's just me.
Quick Reply: E60 for Singaporeans
