Car Coding
#521
Blood, do you know if there is a way to enable to fog lights anytime the headlights are turned on? Automatically or with the switch?
-Erik
#522
As far as i know the fog lights are only switchable with the panel switch, no auto mode that I know of.
#524
Model Year: 2010
Upgrading NCSEXPER from 3.0.8 to 3.1.0 seem to fix the FA option error in my E60.
I was able to code the following modules:
KOMBI - BC_DIGITAL, aktiv
CAPPL - LEGAL_DISCL, nicht_aktiv
The SG_CODIEREN job for KOMBI module completed succesfully with no error. However SG_CODIEREN job for the CAPPL module returned:
Error in CABD! Look at CABI.ERR and ERROR.LOG!
COAPI-2000: EDIABAS or SGBD error
SYS-0020: BASE OBJECT FILE NOT FOUND
I checked the CAS trace file and LEGAL_DISCL has been set to nicht_activ. The DVD-CCC seems to be working correctly. What went wrong? Should I be concerned?
#525
My Ride: BMW E60
Model Year: 2016
I have actually encountered odd errors with CAPPL on some cars a few times. The car would refuse to communication for a few times, but then upon tries, it'll code correctly.
So might be the same case for you.
#526
#527
Model Year: 2010
Thanks to BLooD, nomis_nehc and Bruce for their help, I now have the following coded on my E60:
CAS - KOMFORTSCHLIESSUNG_FB, aktiv
My LMA ECU readout did not have any welcome light parameters, so I didn't code those. I always leave my headlight switch in the off position anyway.
On to my E90 next! I understand the modules may have different names on the E90...
#529
My Ride: BMW 530D M-Sport, Steptronic, Grey Metallic,
Retrofits: Sport Comfort Black Leather, M-Sport Alu Cube Dash Trim, Shadow Line Trim, CCC Pro Nav, Full M5 Conversion, M5 Mirrors, Quad M5, 20" M5 Gloss Black wheels, AC High Panel, Internal Boot Release,
Mods: Xenons, Carbon Fibre Roof, Dension 500, Drilled & Grooved Discs,
i guys i managed to code my e46 fine before with ncs expert i got my e60 back from the garage when i try to process any ecu i get this error any idea whats wrong its a 530d 2003 plate e60 saloon
error in cabd! look at cabi.err and error.log!
COAPI-2041:wrong ecu coding index
A_E60ISI: CODIERINDEX = 08h
any idea guys
any idea guys
