Aftermarket Wheels and suspensions for Xi
Old 05-31-2011, 08:46 PM
  #471
jay bimma's Avatar
I bought them about a year ago from ModBargains through Kevin. They were $1967 plus $75 shipping although I had to wait like 2 months for them to be built in Germany. Their website it straight list price. Ask them for the forum discount.
Old 05-31-2011, 09:33 PM
  #472
saskabush's Avatar
My Ride: 2009 535ix
Ditto on Modbargains.
Install for me was around $600 in Canada. Ride is smooth and no clicking noises from mine.
No regrets on getting the kw v3.
Old 06-04-2011, 11:45 PM
  #473
Rostman's Avatar
Finally get 245/40 R19 and 275/35 R19 tyres. ET32 in the front, ET27 in the rear. Looks great for me.
Rear:
Front:
Old 06-05-2011, 09:34 AM
  #474
TMack's Avatar
My Ride: 2008 535xi Platinum Gray, Black Dakota Leather, Sport Pkg
Pretty darn aggressive in back. What's the rear wheel width?
Old 06-05-2011, 09:47 AM
  #475
Rostman's Avatar
10 inch.
Old 06-05-2011, 01:43 PM
  #476
NoQuarter's Avatar
Engine: N54
On the speed changes... Our speedo is off by 3-4 MPH. Say 3 to be safe. So when your speed gauge says you are goin 70mph you are really going ~67.
This can be confirmed with GPS readings - I have verified with 3 different kind. Also, with NCS coding, you can enable a digital speed display in the cluster and, optionally, enable the digital display to show the speed without this hardcoded offset. Conventional wisdom says it is this way to allow for the variances of tire diameters so the larger the diameter, the closer to the displayed speed you are.
Old 06-05-2011, 01:57 PM
  #477
norsecarnut's Avatar
My Ride: 2008 535xiT6
So you think the speedometer is off by 3-4 mph at any speed? Tire sizes only affect the speed by a %, not a set amount. Have you compared gps and/or mapping distances to verify the 3-4 mph? Is it only the speedometer or the whole system? The tire size change obviously affects every aspect of distance including odometer and thus mpg too.
Old 06-05-2011, 08:11 PM
  #478
TMack's Avatar
I've had four BMW's and they've all had "fast" speedometers. My E90 was about 5% fast. My current E60 is only about 2% fast. Not a huge deal any way you slice it EXCEPT that it also means that the odometer is increasing 2-5% faster than it should, thereby devaluing the car faster. That means there's a "business case" for plus sizing your tires to reverse that problem.
Just my two cents.....
Old 06-05-2011, 10:11 PM
  #479
Kansas City I see? I've been to Baron BMW a few times. So far they've done a great job replacing the nav dvd drive system and general service interval stuff.
I guess my 3% larger tires are just right then! Good to know.
Old 07-11-2011, 01:03 PM
  #480
louveres's Avatar
My Ride: 2008 535xi
Another XI owner here.
Ready to get the Miro 111 for my 535.
Just wanted to confirm with you guys, from what I've read in this thread, I can go with 19x8.5 in the front and 19x9.5 in the back which would coincide with what tire size? My thing is, living in Chicagoland area, I can only use the Miro's in the summer. I want to do winter tires on the stock rims, and just swap them in the winter.
Would the size mentioned above work without any modifications to the suspension, no spacers, would it look good?
I understand that I would also have to move the TPM sensor every time I do the swap?
Any advice for this setup would be greatly appreciated.
Quick Reply: Aftermarket Wheels and suspensions for Xi
