CIC Retrofit Installation LOG
#681
Have been following this thread for a while.
I want to sell my current non-LCI E60 and buy a LCI model.
Currently i have nog navigation.
By adding navigation pro in the car I hope to sell it quicker.
I am looking for a idrive-high controller which i need for a non-LCI CCC navigation professional.
Anyone who had upgraded from the idrive(high) controller to the new style controller and is willing to sell please PM me.
You post has to be 5 or 10+ to use PM feature etc.
#682
I am currently just looking for the idrive controller (high). Already bought a navigation pro ccc.
My current controller (low) does not work.
I own a 530i and am looking to buy a 545i.
#683
My Ride: ///M5 BEAST
just a heads-up....if you are looking to go for an LCI model then buying a 545i will still have you with an pre-LCI E60. The LCI (facelift) did not occur until the 2008-2010 model years (at least here in the States that is...).
you would be looking for a 2008+ 550i if you want the V8....its a great car, i currently have a 545i and i love it to pieces (when im not having issues that is lol).
look on ebay, for the HIGH controller...you will find some CCC units and a couple CiC iDrive controllers as well. i am currently upgrading my non-nav to the CCC navigation professional and decided to do the CiC iDrive controller retrofit to pair to the nav unit. its going to look great, i cant wait!
#684
You don't need to change the controller if you are thinking of getting the old style (high) version to work with your CCC Professional.
#685
Guys, I have managed to brick my CAS module. I was tyring to update that with WinKFP as suggested by SSS and then an error popped up mid way thats all. I can't use key anymore, no ignition, nothing. I tried reflashing but it just says unit not responding. Before upgrading it said UIF can be written 1 more time!
Is there anyway to resurrect CAS? Now NCS simply doesn't work as car is not turning on or anything.
#686
Sorry, it was false alarm. CAS update did fail because of communication was lost but after a while i attempted update again and CAS accepted the update, it failed again but at 12% this time. Retried later and failed at 80%, finally in the fouth attempt it went all the way to 100% and then cas came back to life.
Such a relief. What a scary experience. i almost fainted. INPA gave me clue that cas was alive and responding.
DAVIKEN (01-18-2021)
#687
I need to buy a HIGH old style controller.
Can anyone confirm that a new-style controller will work on this CCC? Then i can buy it on ebay.
#688
And I am telling you you do not need to buy it. Your existing controller can work fine with the CCC after recoding.
#689
Georgieb, tomorrow I plan to do the centre console conversion to fit CIC controller. By any chance do you know if I can take console out without taking off the front dash air vent and associated trims trims? Thing is I have installed everything back together while I waited for parts to arrive, now I don't want to take everything off unless it is required. Mine is LCI version which is different then non-LCIs and I think I may not need to remove shifter stick etc. I did remove the centre console trim once but I don't remember it now. My main worry is two screws in the front which is only accessible if I take everything from dash off including CCC/CIC. Worst case I take everything off.
#690
My Ride: 2007 Black Sapphire 535i
I'm having trouble remembering this myself. If I remember correctly you won't have to remove the front dash air vents and associated trim. You may however have to remove the panel / ashtray where the heated seat buttons etc are.
Good luck with your conversion. Post some pics once you're done.
