CIC Retrofit Installation LOG
#551
Just wanted to put in a good word for Patryk in helping me out with a successful CIC retrofit. He was more than happy to spend extra time fixing up a additional issues that I had and was extremely patient and professional throughout the entire coding session (my wifi would keep cutting on and off which was annoying to say the least).
I have the HiFi option in my vehicle (2007 530i LCI) so I had to do the woofer fix with the whole jump-wiring of a few cables. Prior to the CIC retrofit, I had installed a set of BSW speaker (4 sets of midranges/tweeters) into the vehicle and it sounded fantastic for the price. Now my problem is now even after the wiring fix, is that my rear speakers would have a very profound bass and there would be no clarity at all (if I shifted the sound fader all the way to the rear). If I shifted the sound to just come out of the front, then the clarity and treble is present, however there is no bass presence at all. The only way I can come to a temporary fix is to shift the fader a few dials to the rear to sort of "balance" this out a bit.
What can I do to fix this issue? Sound is a very important aspect for me and how it is currently just doesn't sound right.
[edit] Is there some sort of a OEM sub with the HiFi option? I seem to feel a low rumble in the rear flooring but can't seem to find the source!
#552
#553
My Ride: BMW 530i
Engine: N52N
Those with the Hi-Fi (US standard) sound get hit the hardest when they upgrade to the CIC. First of all, are you absolutely sure that your car is coded for Hi-Fi and not Standard. Next the biggest problem you have now are those BSW speakers. They need to be driven hard to sound good. What has changed is that in the Hi-Fi option the CIC is outputting only low outputs. You have no option but to add a new 6 channel amp. Read my post few above to see how I solved this.
WBANU92000CU35639
I've checked the car itself and can find the front 2 pairs of midrange & tweeters in the door, 2 pairs of midrange & tweeters in the rear, 2 under the seat subs (or so I believe, this total 10 speakers right which if HiFi?), and the place in the dash for the center speaker (however no speaker is present, there is a cable though which seems to plug into an empty housing, can we make use of this at all?).
Now I've contacted BSW and they say that their plug n play amplifier isn't far off from release. Would it be best to wait for them or would an alternative aftermarket option be more suitable? In the meantime though I will look into the temporary fix that you have posted.
#554
The BSW plug and play amplifier is not going to do you much good. Your configuration is not something they will support. After a CIC retrofit the wiring in the car is now incorrect for the configuration. You have two options.
1. Forget about the under floor subs. Get the car recoded for Stereo.
2. Add 6 channels of amplification and depending on how you do it, a whole lot of rewiring.
So unfortunately to have to think about what you want to do carefully. Also I don't doubt you have Hi-Fi, why question was more related to "Has the car been coded for Hi-Fi"?
This is why I mentioned this as a very important step for all those who have the Hi-Fi option. L7 and EU Std are not affected.
#555
#556
I'm pretty sure that it is. I'm in Australia and Patryk said he double checked my VIN and confirmed it to be Hi-Fi. However here it is again if you want to double confirm it:
WBANU92000CU35639
WBANU92000CU35639
The car spec includes the following option:
676 HIFI LOUDSPEAKER SYSTEM
#557
My Ride: E61 535d carbon black m-kit panoramaroof with beige nasca interior and wood trim. 172m rims. DimSport Race, SB, SAT
#558
Quick question on the USB music import function.
Is there a way to sort the imported folders alphabetically?
What I do is this:
Save say 1 album (say 10 songs) on a thumbdrive, and import. I get "USB 1" or something, and then I rename the USB 1 to the album name. In this way, all my albums are at the top level of the music collection, rather than having to click USB 1 and then the album folder then the song.
Trouble is, the sorting goes by "date imported", rather than alphabetically, which makes searching somewhat troublesome.
Any advice or inputs will be much appreciated, thanks.
What I do is this:
#559
My Ride: BMW 530i
Engine: N52N
So now I have 2 problems, what amp to buy and how to do the wiring? I don't really have a budget in mind but anywhere up to around $1000 is good. Can be a bit more if necessary but don't want to overkill the BSW speakers. Speaking of which, how good are the BSW speakers? I got them for its convenience in installation, and I was pretty happy for the price I paid but how do they compare to the rest? Is it better that I sell them off and get a completely different set?
#560
BSW is absolutely rubbish. If you are willing to change the sound now is the time to do it.
