Navagation commands
Old 05-19-2004, 06:11 AM
Tsandas's Avatar
My dealer told me today that the radio is only suppose to lower not Mute. Is that correct??
Old 05-19-2004, 09:27 AM
noonehome's Avatar
Originally Posted by Guest_incite23' date='May 15 2004, 09:17 PM
That is strange mine mutes the Radio/CD while the Voice Command button has been pressed.
From my experience (US Spec. ), when the NAV lady gives a command the Radio does not Mute. I found that while she was giving a command I could use the volume up button to raise the her volume so I could hear her over the radio. Some times her volume would return to a lower level and I'd have to turn her up again.
The voice command Button does mute the radio but it is unrelated to the NAV instruction volume.
Old 05-19-2004, 12:09 PM
incite23's Avatar
On my vehicle, when the navigation lady speak it lowers the radio/CD volume. You can adjust how loud the lady is by turning the volume up/down while she is speaking. On the other hand, when I select the voice recognition button on either the steering wheel or the center console it completely mutes the radio/CD volume. This only makes sense as the system does not like background noise. If there are others speaking in the car or the radio is on the voice results are not nearly 100%.
Just FYI
Old 05-19-2004, 02:54 PM
Tsandas's Avatar
Thanks, I will try it again to see if it lowers it? Maybe I had the volume to low on the navagation voice.
Sou1b1azer
10-14-2015 06:55 PM
ey2001
09-13-2015 03:25 PM
jeffandjaimie
07-08-2015 05:48 PM
legalman
06-14-2004 05:49 AM
Tsandas
05-30-2004 06:59 PM
Quick Reply: Navagation commands
