545i hydrolocked (well maybe)
#51
Does anyone have working INPA for e60 N62?
I have one, but only reading and resetting engine codes work.
Alternatively, I'm looking for a way to re-sync my key with immobilizer.
#52
I'm using the same download that most everyone else is using though, so not sure what the issue is. Was your car updated recently or anything?
#53
Can you PM the location where you downloaded it from ?
#54
#55
Thanks to ncsugrad2006 and few other buds I got the files ME9_N62. I can read error codes, clear errors, read status, but when I go to re-sync EWS I get this error as on the pic.![545i hydrolocked (well maybe)-error1.jpg](https://5series.net/forums/attachments/e60-discussion-2/143161d1482365545t-545i-hydrolocked-well-maybe-error1.jpg)
I'm thinking that I have mismatch of ECU with some parts of INPA. Is that correct assessment or I should be checking something else ?
#56
It has been a while, since I had time to work on 545. But, I finally got some time this weekend and did a leak down test. I stopped the test when I got to one cylinder and found that oil was blown away through dip stick tube. The conclusion is that the engine needs major rebuild or replacement.
I think I will go with replacement and speaking of which are there some good manuals on how to do it ?
Also, what should I watch out when buying a used engine? I've a handful of items, but just want to make sure I'm not skipping on anything.
#58
