iPod interface installation DIY
Old 04-28-2009, 02:28 PM
  #211
schulrog's Avatar
Originally Posted by turbogate' post='861832' date='Apr 28 2009, 04:02 PM
I'm one of them. Car is 2004, 12/03 built. NO NAV, NO CDC. iPod kit runs perfectly. Car STILL does not play MP3. Car may need to be at least a 09/03 built from what I understand.
(I would love for someone that has an tested MP3 cd to send me one to know for sure, but I followed the MP3 DIY and it does not work)
Greg
Thx turbogate I knew someone had done it but didn't remember who. The issue is the hardware... you can't run mp3 CD's but it will still recognize mp3's on the interface and the computer
Old 05-08-2009, 11:06 AM
  #212
superlubricity's Avatar
My Ride: ///M5
Great writeup. Thank you.
A simple 15-minute install in my M5!
Old 05-08-2009, 02:50 PM
  #213
schulrog's Avatar
Always glad to help out
Old 05-11-2009, 03:55 PM
  #214
alexthor's Avatar
Originally Posted by schulrog' post='806068' date='Mar 3 2009, 06:02 AM
you probably have the MASK then and need to get it coded.
What's the MASK? I have a 2006 530xi w/factory CD Changer and no NAV, but I'm having the same problem-- iPod hooks up to the interface, BMW logo comes up, but I can't access CD1-CD6 on the iDrive menu. Dealer says they have to program it and charge me for it.
Old 05-11-2009, 11:59 PM
  #215
schulrog's Avatar
Correct. MASK needs an additional programming for it to work.
Old 05-30-2009, 08:05 PM
  #216
t.cov's Avatar
Originally Posted by Hailander' post='654192' date='Aug 25 2008, 06:20 PM
Thanks for this great DIY and also the advice about the retrofit. I just put mine in today and had the dealer programmed the mp3 retro fit yesterday. Everything works well. The only thing I've noticed is that it takes forever to go from "CD1" to "CD2", etc. About 1-3 minutes. Is that normal?
Thanks for the pics it did help. A few things that I ran into that I thought I may share. I have an 06 M5 with CDC and did not need to be taken to the dealer. I had a tough time removing the power supply from the CDC. I couldn't see the back clearly and did not have enough length to pull it out to see where the power supply was secured to. After some fiddling around, I pushed the latch and then realized that the power supply was going at 90 degrees to the back of the CDC.
Next I wasn't sure the best way to secure the interface so I used the included ties. I used the two longer ties to loop around the front. When this was complete however, the entire unit was secured to the top bracket that the CDC was housed in but.....since the interface has more depth than the available bracket, the entire unit was sliding forward.
I rectified this problem by using two smaller ties and securing the interface from the lateral screw slots to the side openings on the bracket...
Maybe I did something wrong, but it is nice and snug now....
Switching from CD1 to 2 doesn't take me that long, but I am already frustrated than when using CD2 (artists) and listening to a song, going back to root always starts me back at the beginning of the alphabet.
Old 06-01-2009, 11:20 AM
  #217
in4maous's Avatar
I am having a service place that has the BMW Diagnostic system setup code my car this week. Can anyone post or send me the link for procedures to follow using the BMW coding system?
Many Thanks
Old 06-01-2009, 12:44 PM
  #218
schulrog's Avatar
you can download the bulletin @ http://www.aftermarketbulbsshop.com/BMW-iP...bmw-ipodint.htm It should be fairly self explanatory. In the retrofit menu just select MP3
Old 06-01-2009, 04:46 PM
  #219
in4maous's Avatar
Thanks
Old 06-01-2009, 06:50 PM
  #220
craigm1841's Avatar
15 pages of discussion for a 10 minute DIY?
Quick Reply: iPod interface installation DIY
