Coding and registering new battery
#61
Model Year: 2010
What about using EDIABAS Toolset 32? Load SGBD MS450DS0.PRG. Look at the two jobs of interest
steuern_pm_histogram_reset
steuern_batterietausch_registrieren
Highlight the job for histogram reset, then select Job / Start job once only
Screen image attached.
#63
My Ride: BMW
I ended up taking my car to a BMW independent to perform the registration. How can you tell if the battery has been registered properly? Attached is what I see in INPA.
#65
Model Year: 2010
147890 km = 91894 mi
"letzter Batterietausch bei km" = last battery replacement in km
There were three battery resets done three days ago, at 147830 km. That was probably yourself.
I used translate.google.com
#66
My Ride: BMW
Yes. that was me. I used google translate as well but I wasn't sure. So was that the same as the histogram reset? I remember seeing the 147830 before I sent it in to the shop to make sure it was registered properly.
So, was my attempt at battery registration did in fact work even to I get the error I posted the other day?
#67
My Ride: 535XI
Engine: N54
Can someone help.
I code cas Klasse_BatterIe to 90AH_AGM
Remove -080 and added -A090 to cas and lma
In tool32 I selected ecu -MSD80 look for Steuen_.......... then press control J, start job f5, start job con f6.....
in inpa e60, engine msd80, f5,f5,f6
but i field 2 i get 91ah
what am I doing wrong????
#68
My Ride: 535xi Touring | M-Sport | Shadow Line | Slick Roof | SAT shifter | NCS Expert options coded
Hi guys,
I'm having and odd issue changing to a 105ah_agm battery.
Had no issue 90ah to 90ah_agm, and verified 90ah in INPA under the IBS menus. I noticed 105ah_agm option in the CAS module, so I bought a BMW H9 105 Ah AGM battery from the dealership, and I installed it and tried to code it.
VO didn't like me interpolating the code to be -A105 (90ah_agm is -A090), so I left it at -A090 and I coded the CAS module to the 105ah_agm and it took it. I again viewed the battery capacity in INPA, but capacity shows up as 81ah. I redid it at least 3 times, and also verified with my Foxwell NT510 - battery capacity when CAS is set to 105ah_agm shows up as 81ah. Changing it back to 90ah_agm in the CAS module, and INPA and the NT510 show 91ah capacity.
Stumped - I took it to my buddy's house to try Carly. Carly sees the 105ah_agm option and codes it no problem. He goes back in to verify and it shows 105ah_agm selected. Came back home and curious just to make sure, and again both INPA and the NT510 say capacity is set to 81ah. Not sure what to believe, and even more importantly which setting to use.
Has anyone retrofitted a 105Ah AGM battery into their E60 with success? Anyway to add a VO battery code like -A105?
Should I delete the battery VO code entirely, and then use the 105ah_agm CAS option?
Is there anywhere else that it would be getting the 81ah number in INPA for the battery capacity? (IBS module, view #2)
Thanks,
Rabin
Thanks,
Rabin
spitfire23
05-12-2015 04:23 AM
