For the E60, I'm trying to understand the procedure, and I think it may be simple for those of us familiar with NCS Expert and INPA / Toolset.
Verify / code the CAS module with the actual battery type installed: HTML Code:
KLASSE_BATTERIE BATTERY TYPE Register the battery. Use Toolset 32 (under EDIABAS folder):
What do you guys think? |
1 Attachment(s)
Here is the screen of the "Battery Exchange Registration" job in EDIABAS Toolset.
Attachment 122939 |
there are some VO relating to Batteries as well. What about changing the VO and the coding the car using NCSexpert.
Good idea. All BMW Codes list does not show any battery VO string though.
One could just stick with the same capacity, skip the coding, and just register the battery exchange. |
Originally Posted by vkhong
(Post 1359153)
One could just stick with the same capacity, skip the coding, and just register the battery exchange. $992$9AA-B110+NBFD -B110 is the battery code in my FA |
Good stuff, thanks.
I also found this thread: Battery change info Looking at the text in C:\NCSEXPER\DATEN\E60AT.000, I see we're limited to the following batteries for VO: HTML Code:
E B080 BATTERIE_80AH //80 Ah-Batterie |
When I clicked the Job menu there was no Run Job selection,
only
EDIABAS ToolSet 32 version 3.2.7 Before this I did a NCSExpert/CAS module KLASSE_BATTERIE and changed 110ah to 90ah_agm Thanks :thumbsup: .
(Post 1359085)
... Use Toolset 32 (under EDIABAS folder):
Tag'd for future reference. Thanks for the info guys!
I have replaced my 90Ah AGM battery with new BOSCH S5 110Ah and tried to register it:
- in NCS Expert I changed the value KLASSE_BATTERIE in CAS module to 110Ah (if I read the module again the new value is set and correct) - in Toolset 32 I opened MSD80 and executed jub steuern_batterietausch_registri and the status was OK (I also tried with MSV70 and MSV80) But when I check the PM Field 2 in INPA there is still 91Ah as it was before. I also tried B TAUSCH in INPA and also repeated the process. I dont know why it is 91Ah when it was 90Ah battery installed, but shouldnt I see 110Ah now? I have E61 2006. Is the procedure different? Or where could be the problem? Thank you for your suggestions! |
You have to remove -A090 and $536 from FA then code FA_WRITE CAS & LMA, then recode new FA -B110 to cas & LMA end code car.
Also reset IBS with INPA. |
