Aftermarket Wheels and suspensions for Xi
Old 04-24-2011, 10:03 AM
  #381
BlaSTiWi's Avatar
Yeah from lookin' at least the front somethin' not right ... post up more info of what are the tires & wheels sizes are you using?
Compare your front height w/ my pic = http://forums.5serie...post__p__813861
Originally Posted by Rostman
In better resolution
[ ... pics ...]
Old 04-24-2011, 02:41 PM
  #382
Rostman's Avatar
Did your that the gap between the wheel and the fender is to big?
Yep, when i'm looking on you car its much better in the front... Its very strange how it could be like this
I'm using 19X9 ET30 with 235/35 R19 tyres in the front and 19X10 ET33 with 265/30 R19 tyres in rear.
I'm not sure this gap in the front became smaller
Old 04-24-2011, 03:12 PM
  #383
BlaSTiWi's Avatar
Are you using 3-series tires?
Those are rather narrow especially for your wheels that wide... recommended front size is 245/35 and rear is 275/30 ... some go w/ 285/30.
And those recommended sizes are intended for use w/ 8.5" up front & 9.5" rear wide and your wheels are wider ...
But I'm not sure narrow tire play a big role on your strange drop ... to me it seems like something stuck in between the spring or something ...
Old 04-24-2011, 03:22 PM
  #384
Rostman's Avatar
I'm sure you can forget about tyres cause differences between 245 and 235 in overal diameter is 6 mm and 7 mm between 265 and 275.
I bought thise size of tyres to make tyre stretch on a rim.
I checked all parts in the suspensions in Russia and USA and they are the same. What type of shockabsorbers are you using? OEM?
Old 04-24-2011, 05:43 PM
  #385
BlaSTiWi's Avatar
Yup my shocks are still on OEM stocker ...
Old 04-28-2011, 08:14 AM
  #386
v_therussian's Avatar
I don't know what's the deal here, but those rims look downright awesome on E60
Old 04-28-2011, 01:58 PM
  #387
Rostman's Avatar
Put 16 mm spacers in rear.
Old 04-28-2011, 03:36 PM
  #388
Big Boy Bronx's Avatar
My Ride: 2007 BMW 530 XI Alpine White 1997 BMW 328 CI Silver
Hi, I am new to the forum and this is my first post. I just picked up a 2007 530 xi so you can also count me in as 1 of the few with the xi model.Great post v_therussian....
Old 04-28-2011, 04:38 PM
  #389
Welcome BX!
Rost, 16mm? Home made? Looks great! LOVE those rims on the E60!
Old 04-29-2011, 10:00 AM
  #390
saskabush's Avatar
My Ride: 2009 535ix
FYI...From my own experience, 245/35/19 front do NOT work with 275/35/19. When I got my tires, I didn't check to make sure the sizes were correct. Driving above 60kph, the traction control would kick in. I finally realized that the wrong rears were sent. The correct rears 275/30/19 are being mounted today.
I had trouble deciding between 275/30/19 vs. 285/30/19 for the rears. The way I had it explained to me, it depends on what width rims you're running. With a 9.5" rim, 275 is perfect...285 would sit taller and 265 would be stretched and sit lower than the tire size calculator would suggest. Thus, I would think that if I planned on running a 10" rim, I would go with 285/30/19 and with a 9.5" rims, I would go with 275/30/19. 265 may be too narrow.
Rostman, maybe that's why your wheel gap is a little more than others? Because your tires are stretched and probably sitting lower than tire size calculator predicts?
Quick Reply: Aftermarket Wheels and suspensions for Xi
