Opening up e60 headlights?
Old 06-20-2014, 05:40 AM
  #41
CALIC's Avatar
My Ride: BMW E60 3.0d
I honestly think its impossible to simply heat and remove the lens as shown in the video. Because the glue is coving 3 out of the 4 sides, you cannot just heat and remove. However, i think he either removed the glue layer under the plastic bit by bit which will take forever (i tried this on my pre lci headlights and gave up) or it was opened before and he must of used silicon or other heat reactive glue to seal them and used a heat gun to open them up again.
As for the temperature i used, well i didn't measure it but i used my heat gun on low and took my time to make sure the plastic didn't melt of bubble, i cut the sides with a dremel tool, then heat that part for about 7-10 sec with the heat gun then used a sharp blade to cut through the glue where i used the dremel to cut the plastic, then with a screw driver, i slowly peal the plastic and the glue together in one lump.
Old 06-20-2014, 06:38 AM
  #42
Laco19's Avatar
It is possible to simply heat and remove lens without cutting anything. I did it on my first headlight. In this case is outer side of U shaped flange much more damaged but still repairable.
On my another headlights I use utility knife (and some lubricant) to cut sealant on outer side of the lens from top to bottom of the groove. Then I used thin screwdriver to remove maximum amount of the sealant.
I heat only small section of the sealant (about 6"), longer time and slowly so I heat full volume of the sealant not only surface. If I remember, I started on inner bottom side of the headlights.
After opening I removed old sealant from groove.
Old 06-20-2014, 07:23 AM
  #43
CALIC's Avatar
Exactly as you said, the top plastic was damaged on yours. I cut to the chase and just removed the top bit. Personally i think repairing the plastic in your case will look a bit messy. For my headlights all you see is the black sealant which i think will look a bit neater.
And thats what i mentions earlier, you need to remove the glue under the plastic bit by bit. But by just heating and removing the lens as shown in the video i still think its impossible without doing any of the steps i mentioned above. End of the day its a win win as long as the lens is not cut
Old 06-20-2014, 02:11 PM
  #44
tonyb635's Avatar
Yeah, I agree. I think the key is getting it removed where there is no heat damage on the lens and minimal whether cut or heat on the plastic, thats what really scares the hell out of me. When all was removed, how tightly does the lens go back in position?
Old 06-20-2014, 02:44 PM
  #45
CALIC's Avatar
when i tried putting it together (old glue still there), it was a lil tight. After removing the glue it was a bit loose but not much.
Old 06-22-2014, 11:31 AM
  #46
Redtwin's Avatar
My Ride: 2006 535d Sport
Get yourself a tube of Sikaflex 221 and I guarantee the lens will not fall out.
The only thing stopping me doing this is the cost of the V4s I would want to put in them. I have too many other things higher on the list.
Old 06-22-2014, 11:55 AM
  #47
CALIC's Avatar
Thanks mate. Is there any shop thats sells these? as i just had a quick search but couldn't find it in any shops other than the net.
Old 06-23-2014, 10:41 AM
  #48
Redtwin's Avatar
It is mostly used by the body repair trade. If you have a trade supplier (not Halfords or small motorfactors) nearby try them or maybe an actual repair shop could sell you a tube from their stock.
Old 06-23-2014, 11:32 AM
  #49
Laco19's Avatar
.... Personally i think repairing the plastic in your case will look a bit messy. For my headlights all you see is the black sealant which i think will look a bit neater....
I made some photo from repaired plastics that have been damaged when opening.
Sealant can not look better .
Old 06-23-2014, 11:51 AM
  #50
umichchris's Avatar
My Ride: ///M5 BEAST
dont be afraid of using the dremel tool.
ive done over 100 sets now...its pretty easy if you go slowly.
Quick Reply: Opening up e60 headlights?
