CIC Retrofit Installation LOG
Old 04-05-2012, 07:41 PM
  #891
nelson29's Avatar
My Ride: 2005 530i Silver Gray/ Gray Leather. SP,PP
Originally Posted by wtlb
Hi Nelson:
If I do the CIC Retrofit, would I still be able to carry over my Sirius Radio subscription?
I have no idea if that would be possible. Never had satellite radio.
Old 04-06-2012, 08:43 PM
  #892
metroE60's Avatar
My Ride: E60525i: Logic 7, Premium Package, Cold Weather Package, CIC Retrofit, OEM Nav activation, new controller, Combox, 6FL/6NR , Heated Steering Wheel, 6 Speed STEPTRONIC, Bluetooth, 6 CD Changer, Escort 8500 X50 Hardwired, Remus Exhaust, 35% tint, Alufe
Is it possible to turn off passenger side air vents completely? Before I did the retrofit I could control the specific flow from each area (top middle bottom). I can't seem to find how to do that post-CIC retrofit
Old 04-06-2012, 09:17 PM
  #893
balbs's Avatar
My Ride: BMW
Maybe it needs to have some post-CIC retrofit coding done. Just as Patryk posted.
Old 04-07-2012, 02:59 AM
  #894
Patrys's Avatar
The climate control options in the CIC are different from the CCC version.
You need to get used to the way it works now
Old 04-08-2012, 12:20 PM
  #895
bmwspeed's Avatar
I see the climate control is the most important problem after retrofit CIC.
I have pre LCI control climate and with retrofit CIC I change LCI climate module and make some soldering like in this forum.But I need some info how to code the CIC or IHKA for best work:
HVAC_INDEPENDENT_HEATING
nicht_aktiv
HVAC_AIRLAMINATION_CODRV
hvac_high
HVAC_AIRLAMINATION_DRV
hvac_high
HVAC_AUTOMATIC_INTENSITY
aktiv
HVAC_CABRIO
nicht_aktiv
HVAC_FOND_ACTIVATION
nicht_aktiv
HVAC_INDEPENDENT_AIR
aktiv
HVAC_POPUP_AIRDISTR
aktiv
HVAC_POPUP_AUTO_TOGGLE
aktiv
is that correct ????
I think the AC not work : there is no COLD going out the went ???the temperature like outside.When I make 24C at maximum the hot is going ok.Now I drive to check freon refrigerant level.
Or put back pre LCI climate module to check maybe it works OK.
Old 04-08-2012, 01:32 PM
  #896
bmwspeed's Avatar
I make soldering with pin 21 like on picture but AC compressor dont work ?? how to check that?
The green led shines when I press MAX * but no COLD air coming out ??? only the air like outside the car.
Old 04-14-2012, 10:57 AM
  #897
bmwspeed's Avatar
Thank you for your help
I put back my old climate module,soldered pin 21 back.Now all is working good !!!
INPA recognize my ihka.All regulating working ok no error at all.Cold is coming from vents!
Better to have TRUE CLIMATE CONTROL - not mickeys on the screen
Old 04-14-2012, 11:21 AM
  #898
balbs's Avatar
My Ride: BMW
So you put the old one back??? Man, I just bought the LCI version! I want to get it working properly!
Old 04-14-2012, 12:47 PM
  #899
bmwspeed's Avatar
yes i put it back ! the new LCI climate control module need more rework than to solder pin 21.You get several error in diagnostic software and no properly functioning.
Maybe you need to do a lot of rewire or even sensor change.But it is TOP SECRET so its wasting the time to get it work properly.
Old 04-16-2012, 03:55 PM
  #900
balbs's Avatar
My Ride: BMW
Anybody else still having issues with the LCI climate control working on a pre-LCI car?
kevingold03 (11-27-2023)
Quick Reply: CIC Retrofit Installation LOG
