Will a 255-40-19 fit on my 2004 530i?
My Ride: 2004 e60 M5 Replica
Titanium Silver
Premium Package
Premium Sound Package
Adaptive Xenon's
Apple iPhone cell interactive pared with iDrive Bluetooth setting
19 inch BMW OEM 166M rims,
Michelin tires
Sprint Booster - V2
Fidelity / BMW Extended Warranty 7 year / 100,000 miles
Will a 255-40-19 fit on my 2004 530i without any problems i.e. wheel/rim scrubbing, etc?? or should I use a 245-40-19 on a M5 166 Rim?
Thanks in advance
Eddie Presley
Thanks in advance
Eddie Presley
Thanks in advance
Eddie Presley
Thanks in advance
Eddie Presley
The rears dont have a problem so you can go with the OEM spec rear wheel / tires.
Titanium Silver
Premium Package
Adaptive Xenon's
Michelin tires
Sprint Booster - V2
Originally Posted by EBMCS03' post='285903' date='May 21 2006, 10:02 PM
255/40/19 will not work on the E60 on OEM #166 rims. Even the 245/40/19 will rub a little when you fully compress the suspension.
Thanks for your quick answer.
Can this problem be corrected, and if so about how much $ will it cost, or will I have to settle for the rubbing with the 166 using the 245/40/19?
Eddie
Eddie
Eddie
I'm not sure. I dont think so. I just know all that cuz I did extensive research of the #166s when I was looking into getting #166s for my car. But because I cant use the stock M5 tires on the regular E60 I gave up for now. I didnt want to spend money for new tires.
The problems is with 245/40/19 the rubbing is actually lightly touching the fender and not the wheel well... so unless you widen the fender not much you can do with OEM #166s
My Ride: 2007 E63 AMG | Obsidian Black | Schwarzes Nappa | Black BirdEye Maple | Premium II Package | Electronic Trunk Closer | Parktronic
Engine: RPi/Powerchips custom ECU tune, RPi Ram Air Kit (BMC filter, scoops), RennTech Sport exhaust, secondary cats, charcoal and resonator delete, custom AAA x-pipe
Exterior: 50% side windows / 35% rear window Formula One Pinnacle Series | Flat AMG hood emblem
Suspension: Renntech Lowering Module
Wheels/Tires: Radenergie R10, Falken FK452 245/30/20, Yokohama ADVAN Sport 285/25/20
2005 545i Sport SMG | Ti Grau | Schwarzes Dakota | Anthracite Maple | Logic 7 | Nav
Engine: Custom AFE CAI, Superchips ECU remap, Sprint Booster, RDSport Dual Exhaust Conversion with Quad Pipes and X-pipe, 3 resonators deleted, 90mm tips!
Exterior: M-Tech Aero kit | M5 Mirrors | M5 Rear Bumper | Trunk Lid Finisher | Vorsteiner decklid spoiler | 50% Formula One Pinnacle Tint
Suspension and Brakes: Bilstein PSS9 coilovers, JBT BBK: 16" cross-drilled rotors, 8 piston and 15" cross-drilled rotors, 4 piston
Wheels: VIP Modular VR 02 20x9F, 20x10R | Toyo T1R 245/30/20F, 285/25/20R
Lights: PIAA 4150K Xtreme White Plus fog lights, AIB v3
MOST IMPORTANT: Hardwired V1; =)
ED Date: 4/7/05, Re-delivery date: 5/21/05
Check out jsal's profile. He has 245/40/19s on the front with modified offset from 12mm to 14m.
In my opinion, you should just go with 245/35/19s. These will fit your front perfectly.
As for the rear, to better fill out the rear wheel well you can go as wide as 285/30/19s. There a few members here sporting that tire size for the rear.
OFF TOPIC (Sort of):
I am looking to get 166 for a 530. What size should I go for in regards to teh tires? I know the fronts are diff. from the rear, but is it a problem if I go with the same size all around? It is a leased car, so by the time i'm done with the car, the tires will be done too. I just rather have tires that last me the term of the lease (3 years, but winters will be mounted for 5 months every year)
Titanium Silver
Premium Package
Adaptive Xenon's
Michelin tires
Sprint Booster - V2
Thanks so much, I am going with the 245/35/19s will talk to my BMW dealer about changing my offset for 12mm to 14mm.
Eddie
Mihainede85
Mar 11, 2015 09:45 PM
