the way E60 was meant to be
Old 12-21-2015, 06:36 PM
  #711
zenocchio's Avatar
My Ride: 535xit
thanks for the pictures!
how did you connect pins 7 and 9?
Old 12-22-2015, 12:51 PM
  #712
as240's Avatar
My Ride: 2008 6MT M-sport 550i
In this picture you can see that the red and black wires have connector pins at the end of them. I depinned them from the 3 wire connector I bought from Frys. Those pins aren't the same style that bmw uses, but they slide right into the glove box connector and clip in. They are a little loose in the connector, but make good enought contact with the module when it is plugged in to activate sport mode.
Old 01-13-2016, 12:28 PM
  #713
DLF
DLF's Avatar
My Ride: E60 - 2004 - Excellis
Hi,
My car is e60 - 2004 - pre lci.
I would like to put the sport button but I have a box with only dsc button and a little wire. I have any box in glove box.
How could I do ?
I read a lot a things but nothing to help me.
Old 01-15-2016, 06:51 PM
  #714
Andrew06's Avatar
My Ride: 2006 530xi
I just installed a button labeled Sport that lights up in a matching amber color in my Shift Boot bezel, it looks awesome, but more importantly is an absolute blast! The steering literally gets 3 times heavier, the engine/Throttle is a lot more responsive, and the trans shifts harder. It is so fun to have 2 personalities of my car available, it can comfy cruise with the best of em, but it can also get serious. There is a tutorial and explanation on youtube.
Old 02-11-2016, 07:19 PM
  #715
Sai Paladugu's Avatar
My Ride: 2005 530i
Hi guys, Just want to know what module do i edit in NCS expert to get the steering wheel to tighten up. I have a 2005 530i with all the goodies(active steering/servotronic etc) and just did this mod, but dont have the tight steering wheel when i put it in sports mode.
Thanks
Old 02-19-2016, 05:55 AM
  #716
DanielFD's Avatar
My Ride: 2007 BMW 550i
guys quick question as i i'm going to go the OEM root, does the button light up with the rest of the car at night (other then the indicator LED) using just pin #9 and the ground? seems weird BMW designed the button with 4 pins and only 3 are used.
Old 02-19-2016, 10:00 PM
  #717
DanielFD's Avatar
scratch that, found out pin 4 on the button should be connected to pin 4 on X14057 to light up the OEM button at night with the rest of the interior lights.
Old 03-09-2016, 10:43 AM
  #718
Nikola Lefterov's Avatar
My Ride: bmw 535d e60 dpf off,egr off , custom exhaust
So guys its really hard to read all of 72 pages,
So did this SPORT mode , make the automatic tranny shift faster or nop? Im talking about PRE-LCI , since I find pre-LCI ultimatly slow?
Old 03-09-2016, 10:46 AM
  #719
balbs's Avatar
My Ride: BMW
It doesn't shift faster, it shifts at a higher RPM.
Old 03-09-2016, 10:47 AM
  #720
DanielFD's Avatar
Thats weird that i find a lot of people say pre-lci auto is slow, in my 550i its unbelievably fast for a auto trans. It even causes a burp in the exhaust when i shift up at around 3,500rpm
Quick Reply: the way E60 was meant to be
