Sponsored by:
Sponsored by:
Digiprog3 mileage correction on 2004 530i help needed speedo malfunction
Old 01-12-2018, 01:48 AM
Lotto786's Avatar
My Ride: 2004 BMW 530i
Default Digiprog3 mileage correction on 2004 530i help needed speedo malfunction
I bought a digiprog3 mileage correction tool and I attempted to correct the mileage backwards to test out if it works on BMWs as most people said BMW is hard to correct. Long story short after I put the cluster back in it reads 60,000kms when I programmed the eeprom chip I set it for 120,000kms the car originally had 130,000kms.... So the machine wrote it wrong..... So after I put it back in I get speedometer malfunction... Rpm guage comes on on start up then stops working.... Same with fuel guage not working..... My fuel guage is reading wrong as I put $60 of gas in after and it only went up to 75kms range and fuel guage stays low.... The speedometer and speed works..... But now it says dynamic drive malfunction, speedometer display malfunction, active steering malfunction, cruise control malfunction.
any help would be greatly appreciated thanks.
Old 01-12-2018, 03:28 AM
FormerE30Owner's Avatar
My Ride: 2005 545i, premium package, 6sp manual, cold package, navigation package.
Model Year: 2005
Engine: N62
Not sure why you want to do this, nor if its legal, but I doubt that you will get any help here.
james69z28
06-07-2013 02:17 AM
kreveta
01-24-2011 03:43 PM
Presley348
08-22-2010 04:38 PM
530SOunds
03-02-2009 07:53 PM
Techno79
08-25-2007 12:29 PM
Quick Reply: Digiprog3 mileage correction on 2004 530i help needed speedo malfunction
