E60 for Singaporeans
Old 06-26-2006, 07:35 PM
  #6491
RSLK's Avatar
Originally Posted by Yankee' post='303652' date='Jun 27 2006, 11:27 AM
Thanks. Can include me for a Nuvi360 and the Singapore map. Notice the gourp buy is for the map, I added in the Nuvi360, hope this is not so inconvenience.
The Nuvi360 you can purchase from www.expansys.co.uk. It will cost around S$12xx equivalent with S$30 FedDex... If you dun need to whole of Europe map... then get the Nuvi310 at ard S$9xx.
Will include you in the Garmin Sing/JB map order.
Old 06-26-2006, 07:40 PM
  #6492
lmk
lmk's Avatar
Nuvi users:
http://www.theregister.co.uk/2001/01/10/ev...ou_ever_wanted/
we are encrypted la.
Old 06-26-2006, 07:41 PM
  #6493
lmk
lmk's Avatar
Originally Posted by nuvi360' post='303651' date='Jun 27 2006, 11:27 AM
ha ha thats what i thought at first before i did my ice.
and then regret right?
worry not, i believe not only you and me, many poeple had gone through this phase to learn.
Old 06-26-2006, 07:55 PM
  #6494
tcc39's Avatar
Originally Posted by lmk' post='303639' date='Jun 27 2006, 11:06 AM
RSLK and TCC39,
Need your help to confirm something.
when i insert my SD card into the Nuvi, i noticed that there is a click at the top of the slot.
i suspect that there is a nudge which can recognise a Garmin Sd from the rest.
Can you compare a regular SD card and a garmin card? Physically any differences?
On the other hand, there are some softwares in the internet that can read protected memory cards, this way, there may be a crack.
Yes, bro LMK,
I found something unusual there. Notice from the attached picture at the little slot? Approx 1mm to left of the slot there is a little cut. Standard SD do not have this cut.
Please try to use a razor blade to make a cut on a new SD, copy the original Garmin file I sent you earlier and see if it works!!
GOOD LUCK to you man.
I have to go send my car to PML to replace the Windscreen. Sianzzzzzzzz man!!!
Old 06-26-2006, 09:29 PM
  #6495
lmk
lmk's Avatar
Originally Posted by tcc39' post='303669' date='Jun 27 2006, 11:55 AM
Attachment 21031
Yes, bro LMK,
yes, i noticed the cut...and will try.
Old 06-26-2006, 09:34 PM
  #6496
RSLK's Avatar
My 2GB Kingston Ultimate SD has the same cut too... so I don't think it has anything to do with the "cut"???
Old 06-26-2006, 09:41 PM
  #6497
RSLK's Avatar
Would this be the solution to the missing "Country/State" for the MalSingMaps for our Nuvis?
http://www.malsingmaps.com/forum/modules.p...wdownload&cid=3
Description: Updates IMG files from cGPSmapper so that the title correctly shows up when you try to select maps to be used for Find by Address or Intersection in the newer Garmin firmwares.
1. Program does not have to be in the same directory as the IMG file.
2. Command format is: imgtitle filename.img
3. It extracts the title and will write it back to the file in the correct place. It WILL overwrite the original so use a backup if you need to. Running imgtitle without any parameters will bring up a simple description of the syntax.
4. The program will output the title used to screen inbetween so that you know if any spaces got involved. My program will usually truncate trailing spaces.
Version: 1.0 Filesize: 44.00 Kb
Added on: 21-Mar-2005 Downloads: 1229 Rating: 9.0 (2 Votes)
Old 06-26-2006, 10:01 PM
  #6498
lmk
lmk's Avatar
i cut my SD card...
and the results is:....
Old 06-26-2006, 10:17 PM
  #6499
RSLK's Avatar
Originally Posted by lmk' post='303720' date='Jun 27 2006, 02:01 PM
i cut my SD card...
Quick...tell us...tell us you cracked it!
  #6500
lmk
lmk's Avatar
i downloaded the file before but there are no instructions as to how to install and where to put the file?
You know?
Quick Reply: E60 for Singaporeans
