Air Con Problem
My Ride: 535d Saloon - Media Package, Luxury Package, Visibility Package, Tracker - Retrieve, Sun Protection glazing, Heated rear seats, Through-loading system including ski-bag, Steering wheel heating
I have had my 535d for 2000 miles, what a superb car (I changed from a Lexus Rx 300). My air con worked fine (ie set to a desired temperature - then it worked in the background and I wasnt aware of it for most of the time). The windscreen was then hit by a stone and had to be replaced, since then, when the air con is set to auto instead of it working fairly silently, there are sudden prolonged noisey blasts of air - mainly from the windscreen vents - using the i-drive I can see that the windscreen fan is set to maximum during these blasts of air - if I change the setting auto mode is disengaged. Any thoughts ? Is the change of windscreen a coincidence or could some sensors have been damaged.
My Ride: 535D Sport Auto
Have I missed something here but what mist sensor? I didn't realise there was one. Does it automatically switch to the intense windscreen mode if the screen mists up. If it should then mines not working.
My Ride: 535d Auto M Sport delivered 04/10/05, Carbon Black, Beige Ventilated Nasca Leather, Dark Poplar Wood, Media Pack - Sat Nav Pro, Bmw Assist, Bluetooth phone prep + telematics + snap in adapter for Nokia 6230i & 6 CD, Visibility Pack - bi-xenons, adaptive headlights and Headlight Wash, HUD, High Gloss Shadow Line, Extended Lights, HiFi System, Extended Voice, M Spoiler and Heated/ventilated f/seats. Chrome Grills. M Double Spoke 19" Mixed Wheels 172 with 245/35 front and 275/30 rear (Non-runflat continentals) Spare wheel and jack. Supaglass.
Not that I'm aware of. To be honest the a/c is the only thing that I think could have been done better on the car. I miss the old 'internal temperature' settings in digital so that you can tell when the car is pushing the temperature up or down. In my Porsche if I set the temperature anywhere above 22 degrees it was too hot - in the BMW it has to be set to >26 degrees to feel any real warmth.
Problem solved, there is a mist sensor (also known as a de fogging sensor) in the rear view mirrow cluster . It compares temperature and humidity inside the car to that outside, decides if there is a chance of the front window misting and redirects air accordingly. It is fragile and should be replaced if the windscreen is relaced. If you use Autoglass - ask them to ring their technical division, before replacing the windscreen, so they have a new sensor ready, its likely your local branch havent a clue (mine didnt). New sensor on order!
Wow cool. Look how smart the board is! Something new to learn everyday!
My Ride: 535 D - to be delivered end Feb 2005 - color E08 - comfort seats - executive leather balck - 122 wheels - dynamic drive - active steering - pack luxe - tecnology pack - moon roof - 6CD player - hifi system - spare wheel - BT phone
If you select on the ac dash panel the auto setting: it will be automatic: it means that you cannot regulated the diffusion even whith the I-Drive.
The only thing you can regulate is through the I-drive to set the auto mode in 3 psoitions ranging ? weak to strong. It influences the airflow speed.
But maybe you sensor as been damaged?
There is an a/c TIS document on here somewhere - very informative.
The advanced a/c is massively clever, it has about 6 stages of things it does in a particular order, if it senses condensation forming on the front screen.
