advanced air con
i have the advanced air con, i just bought it because it looks better than the standard knobs. But advanced air con is very comlicated.
could someone post the main advanced air con screen in the idrive and say what each control is for?
thanks
thanks
i have attached the following pic.
The box selected in the pic, what is it for? is it for adjusting the temperature? if so, why dont you just use the circular knobs? i think its too much of a hassle to go in idrive just to change temperature if thats what it is for.
the box on the left side of the selected box. whats that for? is it to adjust the speed?
Right, I'm going to try and answer this even without the piccy
as I think I know what you mean.
First a bit of history: Older beemers had a wheel on the central dash vents that allowed you to change the air temp out of just that vent, regardless of what your climate control was set to.
The box you're talking about is just the modern implementation of that - leave it on the middle (white) setting and you'll get the same air temp as is going to all the other vents.
Secondly, the other boxes control the air distribution rather than the flow. Top one for the windscreen, middle one - dash vents, bottom one - footwell.
My advice: Leave it all on Auto, don't worry about the i-drive settings. Just dial in the temp you want and away you go.
The E60 climate control is the best I've ever seen by miles![Thumbsup](https://5series.net/forums/images/smilies/imported/thumbsup.gif)
EDIT: Now I see the Pic!
My Ride: E90 M3
Model Year: 2011
by air distribution, he means you can control how much comes out of the floor vents vs. those on the dash vs. those by the windscreen.
The best way I can describe it is with a couple of examples. (You can actually see the effect of these if you have that screen in the pic showing when you do them, by the way)
1. If you press the rapid demist button the air distribution moves solely to windscreen. None comes out of the central vents or footwell. (The air flow also increases, of course)
2. If you press the MAX cool button, the air distrbution moves solely to the dash mounted vents (along with turning on the air re-circ, and maxing out the fan speed).
In normal operation when you have it all set to auto, the car dynamically adjusts the air distribution for you.
Try it and see.
EDIT: Aha, I appear to have spammed myself to 500 posts
Try it and see.
My Ride: F02 LCI Individual
Model Year: 2013
Originally Posted by browellm' date='Aug 11 2004, 11:54 PM
EDIT: Aha, I appear to have spammed myself to 500 posts ![Tongue](https://5series.net/forums/images/smilies/imported/tongue.gif)
![W00t](https://5series.net/forums/images/smilies/imported/w00t.gif)
Originally Posted by Iceman' date='Aug 11 2004, 10:00 PM
[quote name='browellm' date='Aug 11 2004, 11:54 PM'] EDIT: Aha, I appear to have spammed myself to 500 posts? ![Tongue](https://5series.net/forums/images/smilies/imported/tongue.gif)
Me, no. I can put it down any time I want.
![Online2long](https://5series.net/forums/images/smilies/imported/online2long.gif)
