2008 535i key fob battery
My Ride: 535i
Engine: 3.0L 6cyl Turbo 6M
hello
my 535i key battery never replaced. Do I need to replace the battery. What type should I use. Thanks
CR2032 lithium. Pop the cover off after removing the hidden key. You can use the end of the key to twist off the cover.
http://autoconsignmentofsandiego.com...ccess_Key2.jpg
My Ride: 2008 550i
If you do not have Comfort Access, then your key fob does not have the removable back panel to replace the battery.
In that case, you have to cut open the key fob to replace the battery. And it requires soldering ability.
This DIY is for E90 models, not sure if it is the same for E60: https://www.e90post.com/forums/showthread.php?t=1469784
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
I had my 2 keys done by BMWGM5. I don't know if he still offers the service but you can google for his site. 6 years later and it still works.
BallyM5
16
08-03-2019 02:34 PM
BallyM5
DIY: Do It Yourself
108
07-26-2013 02:17 PM
joebaggg
11-02-2011 10:27 AM
s4iscool
01-23-2008 08:27 AM
