NCSExpert Code Mods
#582
Right, Scrap the LMA module, there was a error somewhere.
And yes i have already located my BC_DIGITAL_V
aktiv
When i apply, i get some sort of error code
Ehssan, I'll break it down for you CAPPL is not in my list, neither is MASK. Only module i have compared is (EGS) that has everything the CAPPL has.
aktiv
#583
My Ride: BMW e60 525Da LCI White, DPF out, Front grill black, Shadow line, license plate super bright led, interior white leds;
Hey i tested a bunch of codes in my car and it worked on lci 07, is cool to have a lot of choices in options to play with these, but these days i installed hifi oem audio in standard uk car, and if you can help me with code , to code the car for hifi, i have ccc. I will do a full diy for install oem hifi in stadard uk cars
#584
Nobody knows i heard to code with $606 or something to change vehicle order but how to do that, i will have to code something else?
#585
Hey i tested a bunch of codes in my car and it worked on lci 07, is cool to have a lot of choices in options to play with these, but these days i installed hifi oem audio in standard uk car, and if you can help me with code , to code the car for hifi, i have ccc. I will do a full diy for install oem hifi in stadard uk cars![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
I may be able to help you.... i have codes backed up.
#587
Update to euro members... CAPPL AND TCU is also the (EGS) module!
LMA is also known as (IHK) module!
My car is a 3 series 2006 model. i'm sure there are people who have different series cars that would find this info useful.
Currently experiencing the kombi digital mph speed display
not working for me. Wonder if my dash supports this mod being BC_DIGITAL_V
aktiv
New to ncs btw, i have followed every instruction but still no luck![Frown](https://5series.net/forums/images/smilies/imported/sad.gif)
aktiv
What? EGS is tranny and the IHK is the Clima control moduel. CAPPL is the CCC applications and the TCU is telematics control unit. It does not change and your car is not special.
If I am wrong please prove it.
It sounds like you don't know how to code with NCS and you're giving out some advice to members with no proof of anything besides your errors. Seriously?
Here maybe this will help you. It doesn't get any more plain and clear
https://5series.net/forums/topic/122...1#entry1430252
#588
Why have you got your panties in a twist? this is 2 hours worth of knowledge that i have gathered... i managed to mess up the reading of each module... i done it the hard way of leaving the program, opening it back up and reading (which again i wasn't reading it right and reading the VO)
I will correct my mistake and be a little relaxed next time. jeez, try and help thinking you got it right and then you get flamed for it lol.
#590
Knows anibody how to code the car for hifi amp?
