NCSExpert Code Mods
#541
Hi guys,
I just started coding my 2007 e60 ( build date 04 / 2006 ) and trying to figure out what kind of light module i have. Can anyone point me where to look for in NCSexpert? I've read a lot and believe mine is mostly likely LM1 but I really want to see that for myself on NCS. Please help. Thanks a lot in advance.
#542
The best way is to look at the LM module physically as the label may reveal much more info.
AFAIK NCSExpert will not say you have LM1 or LM2, based on your build date info you are likely using LM1.
Also, you maybe able to find out some LM2 specific function when your read the LMA, such as most (if not all) function(s) that ended w/ _33 are (IRC) LM2 specific also if it's LM2 you'll find a function(s) that start w/ WL_ that related to WELCOME_LIGHT (not to be exact but somethin' similar) .
Hi guys,
#543
#545
My Ride: Many BMW's
Hi guys,
#546
Good point , let me double check. could have been 9 or 10/2006 . Thanks for pointing that out. Anyway, so if mine is LM1 I won't be able to code my angel eyes as DRL right? My car is currently using the highbeam as DRL . I would like to use angel eyes as DRL or have both xenon and angel eyes on as DRL just like my regular night time light. oh my car is bi-xenon btw.
#547
#549
My Ride: 2007 Black Sapphire 535i
Thanks very much. I'll look for it. I dont' need to take anything apart right?
If you have trouble locating and reading the module, check out my thread on the position (Post #5).
https://5series.net/forums/topic/114...1#entry1351727
#550
After reading so much useful information on this forum I figured I needed to post some results of my coding. I own a 530i E61 LCI MY2009 which is nicely equipped and contains a lot of modules to code
After ordering my cable here(http://www.one-stop-electronics.com/...&product_id=16) it took about 3 weeks to arrive in excellent shape. YES, you can buy cheaper cables, but I didn't want to risk frying a module for the difference of 40 bucks.
With the help of NCSEXPERT and a wonderful DIY (use google to find it) I've read for hours and hours. I've got the cable for a week now and these are my codings, all successful on my car.
CAS:
KOMFORT_EJECT (when engine running, stops engine and unlocks keyfeb by holding start/stop button)
aktiv
KGM:
BEIKLAPPEN_B_KOMFORTSCHL (fold up mirrors on holding close button remote)
aktiv
KOMBI:
BC_DIGITAL_V (digital speedometer is cluster)
aktiv
IHKA:
GEBL_ANZEIGE_AUTO (Climate fan speed display via orange light around manual speed knob)
active
HUD:
BLINKER_AUSSTATTUNG (turn signals in HUD)
aktiv
M_SPORT_HUD (part 1/3 for showing M Hud rev counter in HUD)
aktiv
CIC (CAPPL in older cars):
HUD_M (part 2/3 for showing M Hud rev counter in HUD)
aktiv
CIC_MDRIVE (part 3/3 for showing M Hud rev counter in HUD)
aktiv
HVAC_POPUP_SEATCLIMATE (pops up setting screen in idrive of seat heater after pressing button)
aktiv
ACOUSTICAL_LOCK_CONFIRM (makes birp sound when open/close, not standard on EU cars, needs activation in idrive after coding to work)
nicht_aktiv
LMA:
WL_NSW (Fog lamps come on slowly with Angel Eyes when opening, lights in auto mode)
soft_einschalten
This PWM_ changes the voltage of the normal AE lights and prevents the ugly dimming, even DRL are brighter now. This is a cheap solution and way better then HID, LED etc. It still looks OEM, but a lot brighter!
PWM_AN_SL_V_AL_1_34
wert_01
Other options:
wert_01 13,2v
wert_02 aus
wert_03 13,0v
wert_04 13,2v
wert_05 7,7v
wert_06 7,2v = Standard (Almost no light)
wert_07 13,0v
wert_08 12,7v
Because it's a E61 LCI it has OEM LCI LED lights, except for braking. I retrofitted bulb replace LED braking lights which will all throw error codes on iDrive, despite promising adds on OBD proofing. After switching all of these to "nicht_aktiv" the car is error free.
Weird as it is I needed to disable the _BLK_H also to be able to use the leds without errors.
By the way, forget SMD LED, get "high power leds 7,5w" looking like this: Sample
These codes disable error codes
KALTUEBERWACHUNG_BLK_H_L
nicht_aktiv
KALTUEBERWACHUNG_BLK_H_R
nicht_aktiv
WARMUEBERWACHUNG_BLK_H_L
nicht_aktiv
WARMUEBERWACHUNG_BLK_H_R
nicht_aktiv
WARMUEBERWACHUNG_BL_M_1
nicht_aktiv
FEHLERMELD_CC_RL_BL_2_L
nicht_aktiv
FEHLERMELD_CC_RL_BL_2_R
nicht_aktiv
Hope this helps anyone searching for nice codings. If you live in Holland near Utrecht and want some of these as well, contact me.
Excellent forum guys!!!!
![Hyper](https://5series.net/forums/images/smilies/imported/hyper.gif)
CAS:
aktiv
KGM:
aktiv
KOMBI:
aktiv
IHKA:
active
HUD:
aktiv
aktiv
aktiv
aktiv
aktiv
nicht_aktiv
LMA:
soft_einschalten
![Clap](https://5series.net/forums/images/smilies/imported/clap.gif)
PWM_AN_SL_V_AL_1_34
wert_01
Other options:
wert_01 13,2v
wert_02 aus
wert_03 13,0v
wert_04 13,2v
wert_05 7,7v
wert_07 13,0v
wert_08 12,7v
nicht_aktiv
nicht_aktiv
nicht_aktiv
nicht_aktiv
nicht_aktiv
nicht_aktiv
nicht_aktiv
