how do i remove this???
Old Aug 8, 2004 | 06:43 AM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Elric,
I don't know your location but I'm pretty sure you can upgrade your car (it might need some pre-wiring).
Here's a link to a thread about upgrading to CCC.
I imagine others can chime in as well with additional details.
Good luck!
Old Aug 8, 2004 | 07:50 AM
Guest
Guest
Posts: n/a
Hi Rudy ,
thx a lot. I live in Germany. I will discuss it tomorrow with a friend of mine. He works at BMW as an leading technican and he has the TIS at home.
But he thought, that the wiring will be very expensive. His problem is, that he is very good in solving problems caused by the engine, or other things. But in questions about computers etc., he is not very well.
If you could give me additional help i would be glad about it.
Greetings, Elric
Old Aug 8, 2004 | 07:52 PM
Guest
Guest
Posts: n/a
Can someone please post the instructions on removing this panel??? As I understand it, the MY2005 e60s will have wood on the lower portion, which is currently plastic. I am planning to replace this panel with the newer wood one and will need the instructions on removing and replacing this panel. Thanks.
Old Aug 8, 2004 | 09:12 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Okay Guest, you owe me one! As I said in the earlier reply, this procedure is pretty involved since you have to take apart a bunch of things to get to the part you want to change. There are special tools involved, etc. Also, there are fiber optic cables connected to the CCC that have to be handled with care. Don't say I didn't warn you!
I've compiled the various steps into nine .pdf files. At the beginning of each .pdf is a number that indicates the step order. In some cases, I've subdivided a step into multiple parts. (For example, there is a step 1, step 2a, step 2b, step 3a, step 3b, etc.)
Okay, step 1 is to disconnect the battery (beware of some of the issues noted on the document):
Old Aug 8, 2004 | 09:14 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Step 2a, remove the switches for the hazard warning system, and the central locking system (you will need a special tool illustrated in step 2b):
Old Aug 8, 2004 | 09:15 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Step 2b, the special tool needed to perform step 2a:
File Type: pdf
Old Aug 8, 2004 | 09:17 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Step 3a, removing the wood trim that extends from the center to the right (on left-hand drive cars) -- (you will need the special tools illustrated in step 3b):
Old Aug 8, 2004 | 09:18 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Step 3b, the special tools needed for step 3a:
File Type: pdf
Old Aug 8, 2004 | 09:19 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Step 4, remove center trim:
Old Aug 8, 2004 | 09:20 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Step 5a, remove Car Communications Computer (follow the fiber optic cable notes in step 5b):
