DIY LED Reverse Lights
#21
My Ride: 05 530I
Wow that's some nice bright lights brian928r. It's nice man, you should make an DIY because it looks tight. I would like to do this mod to if you don't mind PM me instructions or an DIY would be nice.
#22
No problem. I'll take pictures and write up a DYI My car is a 2006 525 but i'm sure it'll work for the newer cars as well.
#24
Then installed the slim ballast. I got the relay trigger from the light closer to the battery. If you?re not going to install a switch where you can turn it on and off while driving, you don?t need a diode but if you?re going to install a separate switch, you must install a diode because the computer will think the car?s in reverse when you hit the switch.. As you know, diodes feeds power one way so there will be no feedback in the car?s reverse system. I?m horrible at writing DIY . I?ll attach some pictures. It?s so neat you?ll never think it?s an aftermarket install
#26
so are these obnoxiously blinding like fogs on when there's no fog to begin with
![Devil](https://5series.net/forums/images/smilies/imported/devil.gif)
#27
Here's a picture with the bulb sitting in the housing as you can see I filed the sides of the H11 bulb to fit the socket. The original factory sockets were not touched. The silicone is just there to keep the bulb from moving. The original halogen bulb on the driver side is hidden between the metal frames not touching anything. The wires from the passenger side were used to trigger the relay harness and continue to the bulb which is also again tucked in the metal frame, away from anything. The bulbs are there just to trick the computer into thinking there?s a bulb. The relay pulls the power direct from the battery to supply the Ballast which is triggered from the reverse light. Hope this makes sense
socale39
09-05-2023 08:30 AM
