Car Coding
#411
My Ride: M3 ZCP EX:2005 BMW 535D Sport, Estate, Steptronic, Carbon Black, Black Dakota leather, Head up Display, Profi Satnav, Bluetooth - only MULF module, Bi-xenon adaptive headlights, Sportseats, Cruise control, Active steeringMods: 19
Model Year: 2011
I'm just going to check the message from the NCS, should be here within 30 minutes
#412
Model Year: 2011
There is the actual fault taken from the car now:
ERROR! Modul: CDH.C, Proc: CDHCheckIdent, LineNr: 03, ErrorNr: 2041
COAPI-2041: Falscher SG-Codierindex
A_E60CCC: CODIERINDEX = 0Ch
CCC_APP.C04: CODIERINDEX = 04
>> ERROR! Modul: COAPI2.CPP, Proc: coapiRunCabd, LineNr: 06, ErrorNr: 2041
CODIERDATEN_LESEN
CODIERDATEN_LESEN
CODIERDATEN_LESEN
CODIERDATEN_LESEN
#414
Model Year: 2011
#415
Model Year: 2011
#416
Engine: N54
Jakober... you the guy that got cornering fog lights to work?
#418
My Ride: 2007 E60 535d M Sport
Sorry this is isn't really E60 related... but I just tried using INPA/NCS on a 2001 E39, and a 2004 E46, and neither of them would read any module in INPA, and nothing in NCS either.
E60 works fine for both programs... Any ideas anyone?
#419
Guys, I have two questions, I hope you can help me with these. My mechanic is coding my car with NCS and he is rather experienced with it. However, he has problems with the following:
1. He can not access the steering wheel module (in order to turn off the AM function of the "next entertainment" steering wheel button).
He can access any other module of the car, just not the steering wheel module. He can see it, but not change it.
My car was built in Sep 2004, and its software was upgraded in Oct 2009 at a BMW dealer. My car software was apparently version "04" of NCS and was upgraded to version "0C" of NCS. My mechanic uses the NCS version "0C" but still can not access the steering wheel module - when trying to program it, it says something like "version not compatible", when in fact it should be the same version!
What is wrong? How can we access the module?
2. He can not find a "cold/warm check" (=Kalt/Warmabfrage) for the Angel Eyes.
We want to turn the check function off, so that the LEDs don't strobe.
He finds all other "Kalt/Warmabfrage" functions - for tail lights, indicators, fog lights, rear parking lights, number plate lights, JUST NOT for the Angel Eyes!?!
Is there such a function and where can he find it?
Thanks.
Thanks.
#420
1. Not sure why looking into steering wheel module the audio stuff is either in CAPPL (for Navi equipped car) module or MASK (for non-Navi) module.
2. The parking light is SL_V_R & SL_V_L inside LMA module so in your case since it's 2004 model it'll be using LM1, try to look for the following function:
I'm lost as far as about the error you mentioned in your #1 ... sorry I've no idea what you're sayin.
GL!
Code:
-AE cold/warm check: KALTUEBERW_SL_V_L KALTUEBERW_SL_V_R WARMUEBERW_SL_V_L WARMUEBERW_SL_V_R
GL!
Thanks.
Thanks.
