Dealer Purchasing & Service Forum What's your dealers sales and service department like? Post finance and lease questions here too.
Service Bulletins
Old Dec 4, 2008 | 03:29 PM
  #91
VW2545i's Avatar
Hi, New owner or a used 2005 545i. Purchased through private seller and I just wanted to see if there was a way I could find out what version of software my car was running and if there were any updates needed. In my Passat I would just hook up a VAGCOM and just read the info off the car, but I suspect it is not that easy in the 5s. Any advice anyone could offer would be appreciated.
Sean
Old Dec 17, 2008 | 01:39 PM
  #92
Sam the BMW man's Avatar
My Ride: 2005 BMW 530i Oriental Blue Metalic Beige InteriorPremium PackageCold Weather Package
Any chance of getting this service bulletin 65-30-05 ??? Thanks!
Old Dec 17, 2008 | 06:29 PM
  #93
cobradav's Avatar
SIB_653005.pdf
posted several times around this board
Old Dec 17, 2008 | 06:35 PM
  #94
cobradav's Avatar
Originally Posted by omszz' post='701127' date='Oct 23 2008, 10:53 AM
Could someone post details on SIB 52 06 08 ?
Doesn't 5 series have a similar issue with seat bottoms? At least mine does. I wonder if enough complaints were made there would be some form of service bulletin for the 5 series seat bottoms as well.
Don't remember 5er having this issue
If you really need the whole thing let me know and I'll pdf it and post later on.
SI B52 06 08
Seats August 2008
Technical Service
SUBJECT
Raised Area on the Seat Bottom
MODEL
E82, E88 (1 Series) equipped with Seat Heating (SA 494)
E90, E91, E92, E93 (3 Series) equipped with Seat Heating (SA 494)
SITUATION
GRUSB5208-17
A raised spot or bump may be seen or felt at the rear of the seat bottom (1).
CAUSE
The wire harness for the seat heater mat is loose. This allows the harness to press up against the seat cover just before it's routed to the underside of the seat.
CORRECTION
Secure the seat heater wire harness to the seat base spring.
Old Dec 17, 2008 | 06:48 PM
  #95
cobradav's Avatar
Originally Posted by Fafafoooey' post='695151' date='Oct 16 2008, 06:18 PM
1. Much better feel of the trans after I picked it up today. Seems to go into gear much more smoothly now. And they said that now that the new software is in, the computer will "learn?" my driving style. So that might explain why it took such a hard press of the gas to get a downshift. Now the downshifting is much quicker to response and quite smooth. So much happier now.
2. Also need new brake pads and new brake sensors. Something about them not wearing down along with the pads so they would cause this squealing noise, so they replaced all the pads and the sensors. Nice sensative brakes feeling. Almost feels like a new car with the trans and brakes being all practically new feeling.
3. To cobradav, here is what the Final Report says word for word, since I don't feel like scanning:
Vehicle data status: E060-08-09-515
Target data status: E060-08-09-520
Thanks cobradav for your info so that I could check with the dealer.
Not sure if this report shows anything that you can verify, but here it is.
Vehicle data status: E060-08-09-515 = PROGMAN (CIP) 31.00.00
Target data status: E060-08-09-520 = PROGMAN (CIP) 31.01.00
Rest of the report worth keeping for reference only
Old Feb 15, 2009 | 12:44 AM
  #96
firewired's Avatar
My Ride: 545Ai, Silver grey, black, poplar, Sport Pkg, Logic 7, Comfort seats, Nav, HUD, PDC, rear shades, and satellite radio
How can I find if any SIBs affect my just purchased used 08 550? Thanks.
Old Feb 15, 2009 | 08:26 AM
  #97
Gene's Avatar
as you looks from most recent to older posts, member cobradav posts pdf files....open the them up an see if any 08 e60 SIB's are listed, pertaining to the 550 model
Old Mar 2, 2009 | 10:00 AM
  #98
neoe60's Avatar
+1 Yes, very useful information! Thank you!
Old Mar 12, 2009 | 06:17 AM
  #99
neoe60's Avatar
Thanks for all your hard work on this CobraDev!
Old Mar 28, 2009 | 09:56 PM
  #100
jagbagri's Avatar
when I got the mp3 retrofit I used the mp3 retrofit bulletin to get the mp3 enabled for free under warranty, which clearly states to use program 20.0 or higher to do the mp3 retrofit. Last week when I was at the dealer and asked them for my version number and they said I have E060-05-06-500 which translates to version 17.1
So how can it still be at 17.1 which the car came with from the factory, it?s a puzzle???
My front side markers work, day time running lights work, and more importantly my angeleye eyebrows work and I have mp3 enabled but yet according to thema low CIP version.
Is it possible or they might have made a mistake in getting me my version number. But more improtant question is if IT is correct and I'm on version 17.1 should I ask them to upgrade my software while still under origianl warranty? I don't have any problem with the car (As of today, I have Dension GW500 working perfectly as well).
What is the best excuse I can come up with to get them to update the my PROGMAN.
Thanks
