IHKA, No driver heat
Old Jan 20, 2025 | 04:14 PM
Greggo's Avatar
My Ride: E70 xDrive35i LCI N55 Premium, Comfort Access, Comfort Seats, 4 Zone climate, Vermillion Red
Model Year: 2012
Engine: N55
Default IHKA, No driver heat
Hello, hope someone has new insight into this problem. I am stumped.
Have hunted the forums extensively and not found this exact problem. Similar, but not the same when you dig into it. Most are complaining about too-much heat. That would be preferable at the moment.
2006 E61
Great heat on passenger side, no heat on driver side. Defrost vent is hot from center all the way right. Only a small section on the very center-left is cold and driver window defroster is cold air.
What I know so far:
Using INPA and ISTA+ I can manipulate the flap motors and air flow seems to change accordingly. Coolant seems to be flowing to both heat cores because both hoses are hot and INPA shows the same temperature on each core. Have changed the heater valve just to rule that out. Water pump and thermostat had to be changed because of a leak. Of course bled the system numerous times. The driver heat problem predates the new water pump change.
Watching INPA or ISTA, the flapper motors change position based on control inputs and have matched them on both sides. Still no driver heat. Driver is calling for heat, just like passenger side. Manually setting the flapper position in INPA does not change the situation. I have initialized the flappers a few times, no change. There are no error codes or unusual noises, all seems normal.
All temperature probes appear to have valid, expected values.
At a complete loss. Is one of the flappers broken, based on previous tests cannot pinpoint any failure. What am I missing? Appreciate the feedback and hopefully a lively discussion.
Old Jan 20, 2025 | 05:24 PM
donpb's Avatar
My Ride: '06 530i N52
@Greggo Many members here have experienced that same problem. I do not recall all of their remedies. Please search the forums.
Old Jan 21, 2025 | 04:05 PM
Greggo's Avatar
Model Year: 2012
Engine: N55
I have been searching for a couple of weeks already and could not find anything relevant to my situation. donpb, If you can point me to a thread or post that might help, appreciate it.
Old Jan 21, 2025 | 04:25 PM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
I made a couple posts with the same or similar issue you're having. The first time it was my valve and the second time it was my aux pump. I don't know if you have an aux pump but I'd check that out.
Old Jan 22, 2025 | 09:27 AM
Greggo's Avatar
Model Year: 2012
Engine: N55
Valve replaced, no AUX pump on this car.
Have run through the bleed procedure a dozen times. Head scratcher.
I am about to pull the trigger on a new controller, perhaps it has lost its mind. Easy enough to replace. Not even considering dismantling the entire dash, without hard evidence it has to be done.
Bluesz_
Jul 8, 2019 12:05 AM
Sik_witit
Dec 23, 2015 05:15 PM
Sik_witit
Dec 2, 2015 02:09 AM
natural_nick
Feb 17, 2013 11:11 AM
545OH
Mar 30, 2009 11:14 AM
