Thermostat replacement... This is a real pain!
My Ride: 2007 525xi
Long story short, I need a new thermostat. I already have the replacement, new BMW coolant, etc.
I've lifted the car on jackstands, drained the coolant, and I know where the thermostat is located. I just can't for the life of me figure out how to get it out.
I see the two screws that hold it in, and there are 4-5 tubes going to it. I managed to get one out. The others are still suck behind a jumble of other cables and misc. other things that are in the way.
How much do I have to take apart to get this out?![Frown](https://5series.net/forums/images/smilies/imported/sad.gif)
There aren't any real DIYs here on the forum... already looked near and far. I have BMW TIS, but it's of no real help:
![Name: TrkvS.png
Size: 48.9 KB](https://5series.net/forums/attachments/e60-e61-parts-accessories-mods-22/166103d1683047811-thermostat-replacement-real-pain-trkvs.png)
Note the convenient ""Illustration show coolant thermostat removed" line. =\
I've been going at this since the morning.. almost at my wit's end. Pondering taking it to a local shop if it really is this bad.
On a note about the above.... If I do decide to take it somewhere else, I obviously can't drive it there with no coolant. I don't want to waste all of the coolant I just brought just to drive it over there, where they'll just drain it again. Would it be a bad idea to re-fill the coolant with what I drained out initially (just for the drive over to the shop)?
![Name: TrkvS.png
My Ride: 2006 Titanium Silver BMW 530iA, Sport & Premium Package, Active Steering, Anti-Roll-Suspension, Adaptive Headlight, Navigation, OEM M-Tech Kit, Authentic RD Trunk Spoiler, VIP Modular Wheels: 245/35/20; 275/30/20, OEM M Trunk Finisher.
How much harder is it for you to disconnect the water pump so you can get better access to the other hoses? I know you can do it.
Good luck.
Good luck.
![](https://i.imgur.com/TrkvS.png)
My Ride: 545i Sport
Engine: N62
I replaced my thermostat last June. Remove the underside cover for access to the thermostat.
The TIS instruction is simple, but doing it is a different story (access is a bitch with little working space).
BMW Simple Thermostat.pdf Hope this helps. I removed references to removing the water pump.
Good luck
Good luck
My Ride: 2007 525xi
Attachment 128340 Hope this helps. I removed references to removing the water pump.
Good luck![Thumbsup](https://5series.net/forums/images/smilies/imported/thumbsup.gif)
Good luck
Your thread was one of the ones I looked through
However, in my searches, I've found that the positioning for the 545 thermostat is a bit different than that in a 525. I've found several guides for 545's, 550's, and M5's. Nothing for my lowly 525xi though
The thing is like... in a tiny corner, covered by other tubes. I could probably get at the front-ish three tubes with more time and patience, but I have no idea how to get at that back one.
Would anyone with a Bentely manual be able to scan/take a picture of the relevant pages? Do they say anything about the 525xi?
I'm not sure where to attack those back cables from.
My Ride: 545i Sport
Engine: N62
Not going at the water pump.. =\ That one sounds more risky, and I'd need to buy me some of those aluminum screws that you can only use once if I go there.
timmay77
09-24-2015 09:38 AM
ucsbwsr
09-19-2015 10:58 AM
