M5 cluster made the car younger
Old May 27, 2008 | 12:09 PM
  #21
AlexFW's Avatar
Model Year: 2005
Originally Posted by Puricele7e' post='589315' date='May 27 2008, 08:52 PM
Ok, I understand ;-)
One thing I noticed with the basic setup. Once we had around 5*C below zero, so the crown was showing max rpm 4.000. And I tried only for a very very brief moment (while standing) so see if it goes say at 4.200 and it didn't So it's a variable rpm limiter, not only a moving temperature-rev guide
Sure: you can turn the engine on and wait 5 minutes to have the crown at the limiter: the car suggests you to don't go fast when cold
Old May 27, 2008 | 12:14 PM
  #22
Puricele7e's Avatar
My Ride: BMW 530d titansilver, manual transmission BMW 535d titansilver, automatic + AMG shift Paddles
I knew that, the part I didn't know was that it actually limits the rpm when cold, I thought that was just a suggestion
Old May 27, 2008 | 12:28 PM
  #23
AlexFW's Avatar
Model Year: 2005
Does it limit the rpm ? No puri, I don't think so... Only in N there is a limit at about 5000 rpm .
Old May 27, 2008 | 12:30 PM
  #24
Puricele7e's Avatar
Yes, I'm absolutely positive it does...... It cuts off the ignition at 4.000 (if the engine is cold - note: I got a diesel guys), and you aren't able to rev it higher.
But in neutral (at least in my car), there is no limit, you can rev it to the redline.....Maybe because it's a manual and because it was made in 2003?
Old May 27, 2008 | 12:42 PM
  #25
AlexFW's Avatar
Model Year: 2005
Ah, are you talking about a diesel ?
I don't know then, sorry, but I think on my car I would be able to pull hard till 6000 rpm even if just turned on .
Old May 27, 2008 | 12:43 PM
  #26
Puricele7e's Avatar
Ok now we cleared it up in post #18 I wrote that mine's a 530d so 6.000 when cold for you, 4.000 when cold for me
Old Jun 1, 2008 | 01:59 AM
  #27
AlexFW's Avatar
Model Year: 2005
The cruise control little tab is green (and enlighted!) instead of white!
I got a pic but with the sun you couldn't see it .
BMW565
Nov 6, 2017 06:03 PM
Kasmo
Aug 10, 2015 12:12 PM
shoryuken15
Apr 9, 2015 03:42 PM
lc holmfirth
Mar 22, 2015 10:28 AM
