HELP NEEDED! M5 brake retrofit problem
Old 12-01-2010, 06:58 AM
  #21
525iEnjoy's Avatar
Make sure bleed sequence of LR RR RF LF was used (left=drivers etc)
How many miles are on the M5 calipers and pads?
could be your stock lines are ballooning. have those looked at. how many miles are on your stock lines?
Where the caliper piston and seals in good shape. check the slider pins.
Old 12-01-2010, 07:20 AM
  #22
kdarcia007's Avatar
LR= Left rear??
Probably around 5k miles on M5 calipers and pads, they look new.
Is that sequence absolutely necessary?, sequence of LR RR RF LF was used (left=drivers etc)
Old 12-01-2010, 09:41 AM
  #23
525iEnjoy's Avatar
Right Rear, Left Rear, Right Front, Left Front sorry, I switched the first two
start furthest from the Master Cylinder
yes most cars need it done this way
Old 12-01-2010, 10:02 AM
  #24
545felix's Avatar
My Ride: 05 545/6
Originally Posted by kdarcia007
LR= Left rear??
or perhaps they didn't attach one of the lines properly. Is the system leaking fluid?
Old 12-02-2010, 01:19 PM
  #25
kdarcia007's Avatar
Just came back from the shop, I asked them to do a test:
1st- put on the old stock brakes and do a test to see if they brake hard?
Result: they brake hard
2nd: do the same thing but with new M5 stocks, to see if they brake hard?
Result: they don't pedal is still very soft and braking sucks!
Pads, calipers and rotors are in great condition.
Question: does it affect if they don't use the vacuum to change the brake fluid?
They were gonna take the car to a place where they do it with the vacuum, will it work?
At this point we don't what could be the issue, any suggeations?
Old 12-02-2010, 03:17 PM
  #26
545felix's Avatar
My Ride: 05 545/6
either you have a leaky piston seal on one of the calipers or one of the calipers has air in it and hasn't been bled of it.
Old 12-03-2010, 01:04 PM
  #27
kdarcia007's Avatar
Hey guys, no air in the calipers or lines.
We did a test, we left the rear M5 calipers and installed the stock 530i calipers in the front.
Result: braking power is hard upfront and soft in the back...
Logic: seems the stock brake pump is to small for the bigger M5 calipers, that makes sense?
My car is a 2004 530i, should I replace my brake pump with the BIGGER (in CC's) M5 brake pump?
Old 12-03-2010, 01:30 PM
  #28
toyota2bmw's Avatar
Still doesn't make sense. Memeber 525iEnjoy has done this without issues without such issues. This still sounds like there is air in the system. Is your shop BMW qualitfied? There's one more method of bleeding the brakes using the GT1 computer. There's what's called a DSC flush. My indy guy did this for me a while back where your car will be hooked up to the computer and the DSC unit will circulate as each corner of the brakes are bled. The process fills the DSC unit will fluid to make sure there is no air in the system.
Old 12-03-2010, 03:23 PM
  #29
Masterspy's Avatar
My Ride: 530I Silver gray with gray leather with Premium Package, Logic 7 Premium sound system with Ipod interface, xenon adaptive headlights, Active steering, Power retractable rear sunshade, Comfort seats, Cold weather package and M5 OEM 166 wheels, Sprintbooster. Ceramic Tint all around, Bilstein Sports shocks with Eibach springs, Brake performance Rotors and Axxis ceramic pads.
If all the lines are okey and no air in the system, maybe it is a defective M5 caliper. Just my 2 cents
Old 12-03-2010, 03:33 PM
  #30
kdarcia007's Avatar
How can we find WHICH caliper is defective?
Quick Reply: HELP NEEDED! M5 brake retrofit problem
