E60 headlamp assembly connector
Old May 17, 2025 | 08:26 AM
E 60 Alonzo's Avatar
Question E60 headlamp assembly connector
I purchased Halogen replacement headlamps for my 2010 528i E-60 and they have the wrong connector...
Hella PN's: 1EF 008.673-111 & 1EF 008.673-121 Halogen
The vehicle has a 12 pin flat blade connectors (only 8 of the slots have pins) and the new headlamps have 8 pin round connectors (only 7 of the holes have pins)
If I am correct, the vehicle has LCI headlamp assembly connectors and the new, Hella headlamp assemblies have pre-LCI connectors...
Unfortunately, I don't have a clue what LCI stands for or what differences the wiring has...
Does anyone know if there is an "adaptor" plug that will solve the problem?
If so, would I need to run a wire that would connect to the tail lights?
Old May 17, 2025 | 12:39 PM
kd7iwp's Avatar
My Ride: 2009 535xi Touring 6MT, 2019 i3s
Engine: N54
LCI stands for Life Cycle Impulse, it's BMW's way of saying facelift because usually a few years after a model redesign they will do some sylistic tweaks. Since yours is a 2010 it is an LCI (I believe 2008 is when the E60 had its LCI debut). Everything on your car should be LCI.
Old May 17, 2025 | 01:15 PM
Thanks for the info!
I guess I need to return the pre-LCI headlamps and try to find the correct ones...
tjackson9810
Jan 22, 2015 12:30 AM
Pearl2
May 13, 2014 11:54 PM
KOC
Dec 12, 2012 10:27 PM
m3racer08
10
Apr 10, 2011 06:55 AM
rollee
Apr 20, 2007 11:52 AM
