E60 CIC Retrofit, USB, Combox - 2006 BMW 530i
Old May 19, 2022 | 09:16 AM
  #71
kirvedx's Avatar
My Ride: 2006 BMW 530XI, CIC/Combox/TPMS Retrofit (CCC M-ASK Orig)
Engine: N52
Originally Posted by Bmwpower530
Not specialist here, but i think you can code VO in other units, for example: like you do combox retrofit you have to code new VO to cic using ssd file, other way combox control will not appear on cic or you change some units, you have to code them to your car. I think LM and CAS just saving VO.
You FA_WRITE the VO only to the CAS/LMA or the CAS/FRM (depending on the car). However, you SG_CODIEREN any modules - which default codes them by the VO written to the respective modules (the process requires you to read the VIN/VO from those modules prior to coding). Still, you can set the VO to be written, and then SG_CODIEREN a module without actually FA_WRITE'ing said VO to the CAS OR LMA first; You simply read the original VO from one of those respective modules, then modify the FA, then go ahead and process an ECU. This process gets to be time consuming, however, and so an SSD file is a much more efficient way of choosing the VIN/VO combination you want NCS_EXPERT to use when SG_CODIEREN'ing modules.
Hope that helps to clarify that for you. You should not FA_WRITE other modules.
Old May 19, 2022 | 09:17 AM
  #72
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
When in comfort mode you should be able to just choose the ECU family and the program does the rest.
If you updated the HU_CIC you also need to update both ZGWs and the CMB_Media.
Old May 19, 2022 | 09:21 AM
  #73
pavjayt's Avatar
My Ride: E61
Model Year: 2009
Engine: N54
When I'm comfort mode you should be able to just choose the ECU family and the program does the rest.
Yes, Sean, thats what I remember you mentioning before. But as I have shown in post#41 above, I am not seeing any of the CIC modules at all in the list
Wish they show up, then the rest might become easy
Old May 19, 2022 | 09:25 AM
  #74
You shouldn't see any CICs you should see something like CMAxxx. Whatever shows up in SGBD in INPA that's what you should be looking for.
Old May 19, 2022 | 09:28 AM
  #75
Have you updated your files also on the computer? Also update the dependencies before continuing
Old May 19, 2022 | 09:31 AM
  #76
pavjayt's Avatar
My Ride: E61
Model Year: 2009
Engine: N54
INPA shows CICR as SGBD for module at address 63
while I dont see any module like that in the ECU list
which is confusing me
Old May 19, 2022 | 09:36 AM
  #77
pavjayt's Avatar
My Ride: E61
Model Year: 2009
Engine: N54
I am using V67 daten files and updated winkfp using bmwcodingtool and also directly from winkfp.
when you say "update the dependencies" probably this is the key for me, but I have no idea what dependencies need to be updated and is it using winkfp?
These are all the modules I have
thanks
Old May 19, 2022 | 10:43 AM
  #78
Do you have a mask option? Did you always have CCC/CIC
Old May 19, 2022 | 10:46 AM
  #79
pavjayt's Avatar
My Ride: E61
Model Year: 2009
Engine: N54
It came with CCC with Pro Nav which I replaced with CIC
Old May 19, 2022 | 10:48 AM
  #80
You're using E60 or E89 daten
