Coded some extra menu options.
#232
My Ride: MY2007 (01/2007) E61 530d Sport Futura 231 hp - Sport automatic gearbox - GPS Pro - HUD - Air Conditioning, automatic with extended features - bi xenon adaptative headlights - Night Vision - TV Function DVB-T - Active Cruise Control - Panoramic glass sunroof - PDC F&R - Active Steering - Sport Steering Wheel - HiFi Pro Logic 7 - Bluetooth + telematics - Electric fr seats with driver memory - Alarm ...
Ok and do you know how the "Process car" function is working?
Because in the FSW_PSW file their are some additional options wich appear for all models, include not compatible options for our cars...strange!
#233
Process car just codes all the modules in your car, useful for doing retrofits so that you can make sure all the modules needed get coded.
#234
Because when you read the entire car some settings are not the same as the settings in the module (ie: DWAS)...very strange!
#235
Theres no backup function in NCS, the only way to back up the trace files is to copy each one as you read the modules.
#236
#237
#238
Yes i know that, but maybe their are a way to correctly coding some settings...ie ALARTYP in the DWAS module? i'm affraid to try it because i don't control enough the process.
#240
Can anyone who sucessfully retrofitted a genuine IPOD interface confirm whether the built-in CCC CD/DVD slots are still playing MP3?
I lost this functionality during my IPOd retrofit coding.
First I had retrofitted MP3 playback for the internal drives through DIS and they both played back MP3 CD/DVDs.
Recently, during my IPOD retrofit I have first coded (or better said left the MP3_CCC setting on "full"), but the IPOD did not work, then I changed it to "full" and "extern" in a new line below. After a restart the IPOD worked and reading out the module again lists only the "full" switch, the "extern" is gone. I am not sure whether the "extern" worked or I made a more thorough restart of the CCC.
However, I suspect that runined my internal MP3 playback.
How can I enable both?
Regards,
Straba
Regards,
Straba
