Coded some extra menu options.
Old 01-22-2011, 01:52 AM
  #111
andy545's Avatar
Model Year: 2005
Engine: 545i
Originally Posted by Ehssan
Thanks Andy for great sharing , I managed to have my cable with USB to serial adapter to work yesterday ... I gave it a try today morning to read some NCS files but it give some error during reading from ECU ... will check it out and then follow your steps .. I would love to activate all the above options ,, some of then already there but still nice to activate the rest ..
do you have a screenprint of the error ?
Old 01-22-2011, 02:01 AM
  #112
andy545's Avatar
Model Year: 2005
Engine: 545i
Originally Posted by BLooD
Just looking through the HUD trace, there a couple more you might want to try unless there already working:-
TELEFON_AUSSTATUNG
set to AKTIV, looks like it shows incoming call info.
ENTERTAINMENT_AUSSTATTUNG
set to AKTIV, looks like this shows entertainment info.
As for M_PARAMETER it only has one setting and thats wert_01
M_SPORT_HUD has three settings :-
aktiv, aktiv_handschalter and nicht_aktiv.
NAVI_AUSSTATUNG has two settings :-
high_guiding and low_guiding.
Cheers Blood, yeah noticed those one - will give them a try and see what comes up.
some q's:
  • how can you tell if a parameter has only 1 or more values ?
  • I never tried activ_handschalter on the M hud - any ideas what to expect to see there ?
  • what does NAVI AUSSTATUNG do?
Old 01-22-2011, 02:22 AM
  #113
BLooD's Avatar
I would assume navi is to do with navigation. I have program that reads the trace files and can tell what parameters and functions are available.
Old 01-22-2011, 02:40 AM
  #114
andy545's Avatar
Model Year: 2005
Engine: 545i
cheers, does NCS dummy do that as well ?
Old 01-22-2011, 03:03 AM
  #115
Ehssan's Avatar
My Ride: Many BMW's
attached , I've checked it on the bimmerforums.net and some one advised to use v3.10.0 instead of V3.08.0 , so I will try it once I'm back home ..also INPA gives error every time I click on E60 , it said " Can't find configuration C:\INPA\bin\..\E60.eng "
Old 01-22-2011, 04:32 AM
  #116
BLooD's Avatar
NCSdummy is what i use for that perpose. Ehssan? did you update the .prg files in the ediabas fodler?
Old 01-22-2011, 05:34 AM
  #117
NoQuarter's Avatar
Engine: N54
TELEFON_AUSSTATUNG
I have tried these on my '07 and '08 and didn't notice anything different.
The M Hud settings work for me but I lose one of the 2 steering wheel buttons in the iDrive menu (The star and Diamond)
Old 01-22-2011, 05:38 AM
  #118
andy545's Avatar
Model Year: 2005
Engine: 545i
OK - I tested some settings:
TELEFON_AUSSTATUNG
set to AKTIV, looks like it shows incoming call info. --> didn't notice anything new
set to AKTIV, looks like this shows entertainment info. --> did notice anything new
As for M_PARAMETER it only has one setting and thats wert_01 --> no changes
aktiv, aktiv_handschalter and nicht_aktiv. --> activ_handschalter didn't improve the current situation...still no MHUD after 30sec
high_guiding and low_guiding. --> nav directions didn't show on HUD anymore with the setting set to high. reverted back to low.
Old 01-22-2011, 05:46 AM
  #119
Ehssan's Avatar
My Ride: Many BMW's
No dude , I didn't update anything ,, I've downloaded the V40 already ,, so should I do anything with it ??
Old 01-22-2011, 07:11 AM
  #120
andy545's Avatar
Model Year: 2005
Engine: 545i
yeah, I lose one too. Apparently the M5 streering wheel has a different button setup. I'm prepered to lose it if I can get MHUD though.
So, do you get the M setiings (Mview) on i drive to stay activated ? So on your HUD you can alternate between your normal HUD and the Mview - correct ?
would appreciate if you could post or pm me your CAPPL and HUD trace files so I can check out your settings Just save a copy and add ".txt" at the end.
Quick Reply: Coded some extra menu options.
