CIC Retrofit Installation LOG
Old 01-10-2011, 10:28 AM
  #441
Patrys's Avatar
Originally Posted by roadrunner1
IceyTys, warranty is a consideration that i have been fighting with. I even have extended warranty. When it's time for updates i would have to switch units back to CCC. Not sure if the mod will effect my warrant it is something i need to clarify with my service advisor. I'm sure it will be affected or they will say it well be affected. I may have to put this mod on ice for a bit if that is the case.
The warranty will not be a problem if you swap the CIC with the CCC before taking your car in. The process is easy and quick when you do it the second time.
I have customers who take their cars with the CIC to BMW with no issues, but I guess it depends on your dealership.
All parts are OEM, so I don't think they would have a right to void your warranty. No coding is needed when swapping the units, so personally I can't see a reason why they would like to void your warranty.
Old 01-10-2011, 09:07 PM
  #442
nelson29's Avatar
My Ride: 2005 530i Silver Gray/ Gray Leather. SP,PP
+1
Old 01-10-2011, 11:31 PM
  #443
cookiesowns's Avatar
I already have the 2009.12 CIC installed in my 2010 E60 535i. Does it come with the combox? Is there a way I can tell?
Do you think just a software update would be enough to have the mobile office feature?
Old 01-11-2011, 12:35 AM
  #444
Patrys's Avatar
The Combox was never officially available for the E60. If you are interested in doing this retrofit send me an email at info@modyfikacjebmw.pl
Patryk
Old 01-16-2011, 04:27 AM
  #445
injener's Avatar
Hello guys, I'm also going to do such retrofit, planning to start with changing old controller to new one. One thing is confusing me - the plastic frame for controller. Nelson said in this comment that you need 51169155970 and 51169155987. On the factory vehicle it looks like this:
But on Georgieb's photo it looks different, with wide border: Here
Can you tell what's p/n of the frame on the last link? I found no BMW models with such frame.
Thx!
Old 01-16-2011, 11:21 AM
  #446
nelson29's Avatar
Thx!
Yes, the p/n that i posted at the beggining were not the correct one. Contact Patryk for more info on the correct frame.
Old 01-16-2011, 11:55 AM
  #447
nelson29's Avatar
Russ @ Octave just finish installing the controller for me, he also installed the SAT shifter refrofit
Attached Thumbnails CIC Retrofit Installation LOG-car-pics-039.jpg   CIC Retrofit Installation LOG-car-pics-040.jpg   CIC Retrofit Installation LOG-car-pics-041.jpg
Old 01-17-2011, 10:53 AM
  #448
RootKit's Avatar
Guys, the USB cable was a bit tricky routing it to the back of the glovebox. I don't think it was necessary to take the glovebox out. But I'm a couple inches short, it seems like I didn't route efficiently. It's the yellowish white cable? Unless I substituted a different cable that had a shorter length? Any suggestions?
Old 01-17-2011, 02:29 PM
  #449
RootKit's Avatar
Ok, thanks for the tip Patrys.....it was through the passenger footwell.
Old 01-17-2011, 03:37 PM
  #450
bruce_miranda's Avatar
Just something before I publish a full DIY. IT IS POSSIBLE to swap the LCI A/C buttons into the pre-LCI AC. Doing this is much safer because I know my car is fine with the current AC. But it requires a lot of time and patience.
For anyone starting this mod I would recommend the following order.
1. Install the CIC controller.
2. Modify the A/C.
3. Work out what you are going to do about the sound if you have the EU Hi-Fi (US Std) sound. L7 and Individual Sound guys don't need to bother with this.
4. Lastly swap out the screen and CIC itself.
This way you are doing the most time consuming parts first. Ofcourse if you have no patience reverse the order but be prepared to keep pulling things out again!
Quick Reply: CIC Retrofit Installation LOG
