CIC Retrofit Installation LOG
#321
My Ride: 2007 Black Sapphire 535i
The LCI A/C panel might work without any coding or programming after you modify the way it is connected. It depends on the software version of your panel. There is no problem to code it and if it still needs to be programmed we can arrange that too.
Just make the changes benhur65 suggested and let me know how it goes.
#322
My Ride: 2005 530i Silver Gray/ Gray Leather. SP,PP
Nigel,
look what came in a couple of days ago
This is the best $100 you gonna spend in your car audio upgrade
Respect to Technic
Respect to Technic
#323
My Ride: M3
Model Year: 2017
... remember to transfer the MOST harness (two fiber optics cables in a connector socket) to the PnP harness; it just unplugs from the OEM Quadralock and plugs right into the new Quadralock harness in the same slot.
#324
Nigel,
Look what came in a couple of days ago
Technic,
Thanks a million for the great work you've done with the cables to allow for seamless integration of my new sound system. Everything looks professionally made. You da man!
#326
Hey Nelson,
I've added a new thread to the forums for my sound upgrades. We can start to post info their on this topic if you wish.
https://5series.net/forums/topic/103...4#entry1237384
With regards to the Climate Control; I've been talking with Patryk and in the event that we do need some more firmware mods on the CIC once I install this I'll wait until you can send me back the OBDC cable for programming. I'd rather not upgrade the stock wire harness for the LCI Climate control only to find out I need to program also. Then I'll have to revert back to the old Climate Control until you send the OBDC cable back.
So, no worries at all! Take your time with the cable, get all your programming done, then once I have it back I'll complete the Climate Control Mod. (You may also want to do the Climate Control Mod before you send me back the OBDC cable just in case you need programming too).
#329
There is some very good news I want to share with you
The new iDrive controller installed without the need to change the center console trim. How does it sound to you?
http://img824.imageshack.us/img824/1218/idrive.jpg
#330
Thanks for the update!
