CIC Retrofit Installation LOG
#1021
I understand that's what year responded bimmerretrofit
Good day Francesco,
I apologize but we cannot email any instructions or technic description before you become our customer and place an order.
As for the light pelase do not worry. We have sold over a thousand CIC kits for E6x series and I can ensure you that lights fix can be done by you. It is our unique method which our engineers developed for all E6x series use.
Regarding the LCI climate panel - if you sure that your vehicle already have LCI panel then you do not need to worry and you will not need to change panel.
Only if your vehicle comes with pre-LCI panel then you need to change it if you want to have all functions working with iDrive.
Thank you,
Kate Ivanova
Customer Relations
Bimmer Retrofit
________________________________
Good day Francesco,
Thank you,
Kate Ivanova
Customer Relations
Bimmer Retrofit
Here's how to do it:
BMW Coding Forum
and
https://5series.net/forums/e60-parts...1/#post1406825 (post 815/816)
Basically pin #14 connected to light power on the hazard switch.
#1023
My Ride: 530d LCI 2007 Msport
thanks all ok now you turn it all but I have a problem or activated voice command of navigation but my car does not have the microphone as I can mount it?
#1024
#1025
My Ride: BMW 550i
finally managed to cut a hole in old console for cic controller was limited on tools so only used what is on the first picture. don't ask how I did it use your imagination
TPIOlds (01-02-2021)
#1026
#1027
You didnt need to do that, I fitted a CIC controller and it turns out the pre-lci shifter bezel will fit an LCI trim panel.
#1028
My Ride: BMW 550i
it wasn't about gear knob gaiter I could not find console trim in same colour for long time and did not want to buy a new one. console trim cut is a bit risky but if you confident and go slowly you will get good result
#1030
Thanks for the update. I am waiting for my order from Patryk this week to do the retrofit. I ll let you know how it went.
