Aftermarket Stereo
Old May 9, 2009 | 10:49 AM
  #21
nelson29's Avatar
My Ride: 2005 530i Silver Gray/ Gray Leather. SP,PP
Like i said earlier, i removed and sold most of my alpine stuff and decided to go back to using the factory source because of a new product that came out named the Audison BitOne. this is the ultimate oem factory integration dsp unit.
Heres a before and after set up on a E92 M3.
With this set up you can keep your factory radio. Theres no reason to add an aftermarket radio if you have the BitOne. Believe me using your factory radio with the bitone will kill most aftermarkets radios.
If i were you, this is what i would do.
1. Buy a Audison bitone.
2. Get a portable navigation unit.
3. Dension 500 for your ipod and usb.
4. Your choice of amps and speakers
5. Your choice of subs.
Believe me this will save you a lot of money and headaches. Your install will be a lot simple and you get to keep your steering wheel controls.
Here's a screenshot of the Bitone software.
Old May 9, 2009 | 09:14 PM
  #22
dbpack's Avatar
What does the Bit-One actually do?
Old May 10, 2009 | 06:59 AM
  #23
nelson29's Avatar
Here's a couple of E60's with aftermarket radio. E60.net member KU530 is the owner of the first vehicle.
http://www.diymobileaudio.com/forum/diyma-...w-5-series.html
http://www.diymobileaudio.com/forum/diyma-...-sq-set-up.html
Old May 10, 2009 | 07:24 AM
  #24
nelson29's Avatar
Its the ultimate advanced factory oem integration unit that works like the Jl cleansweep but its 100 times better. It de-equalize your factory source and sends a clean, flat signal going to your amps.
Its also a DSP with 31 band graphic EQ per channel, 8 channel time alignment, 8 channel hi,lo and bandpass crossovers.
Here's the owners manual.
Bit_One_Advanced_Manual_1.1_ENG.pdf
Old May 10, 2009 | 03:24 PM
  #25
Sagar's Avatar
My Ride: 2006 523i M-Sport
Attachment 79100
Nelson, where did you source your inputs for the BitOne? Speaker Level froom the factory amp?
Old May 10, 2009 | 03:34 PM
  #26
Alpine White Girl's Avatar
crazy setup there. too much work and money for me but im sure it sounds awesome!
Old May 10, 2009 | 04:41 PM
  #27
nelson29's Avatar
I got it from the front speaker outputs coming out the M-ask headunit and the speaker level outputs of the rear amp that powers the 8" subs under the seats. You will need both to reconstruct the signal.
When did you buy yours? Some people are having issues with the first production batch.
Old May 10, 2009 | 06:26 PM
  #28
crmb's Avatar
I can't believe that horrible center channel they did in the first link. That is just awful looking.
Old May 10, 2009 | 08:46 PM
  #29
Eugene134's Avatar
My Ride: F10 535I
Model Year: 2016
I complete after market system is very doable in these cars, it just takes a little more work... See my pic and audio components.
Old May 11, 2009 | 11:33 AM
  #30
Fetish's Avatar
My Ride: Gone: 2004 545i
+1
Seems like everything else fits well with the car, but that looks so out of place.
bestofthebest
Mar 28, 2016 02:47 PM
wraduenz
Sep 25, 2015 07:40 PM
vince_e60
Sep 23, 2015 02:25 PM
kavkaz777
Sep 15, 2015 12:18 PM
Kaane
Sep 6, 2015 04:01 PM
