the way E60 was meant to be
Old 05-04-2013, 06:48 PM
  #421
YRUSRACE's Avatar
I finally installed the cable today, and let me say WOW, what a difference. You just cannot go wrong with it. I already have the BMS Powerbox installed but after this sport mod this car is a whole different beast. Especially, I just the way steering feels. Only negative is that no "sport" image on the cluster unlike pre-LCI guys. If someone knows how to bring it up on the cluster for us LCI folks please do share. Till next time.....
Old 05-05-2013, 02:46 AM
  #422
ah_heng's Avatar
My Ride: 520D 2008 E60
Originally Posted by Cockers
Part 2..
Then I simply inserted the 2 pins I made up into 7&9 (I will attach part numbers at the end, all parts from Maplins in the UK).
Attachment 141124
Then put the housing back on, plug the White box back in and put it back where it belongs, I then run the other end of the cables up to the left and out by the passenger air Bag (you need to remove the length of trim that runs across the front of the dash, instruction in one of the attached videos earlier, its easy, just need to jimmy it a bit).
Attachment 141125
Attachment 141126
Then I run the cable across the car and through the centre console unit, again instructions to remove this are in the previous videos, its only a couple of screws. I then worked the cable to where the steering when adjuster is and left plenty of cable as I'm not sure where I am going to place the push switch yet.
Attachment 141127
Attachment 141128
As I said in my previous post, I may purchase a switch with an LED, or even the original parts for the gear shifter, but for now it works perfectly just no 'sport' light on the dash.
I will post pictures of the parts I used in the next post, they are all available from Maplins cheap enough (less than £5 for the lot).
Get out there and do the mod, you wont regret it.....
Hi there.. wow.. great mod!
Can I ask why is your "process" different" compare to the one shown on the YOutube Clip?
Thanks...
Old 05-05-2013, 07:12 AM
  #423
balbs's Avatar
My Ride: BMW
Cocker's car is LCI. The YouTube clip is for pre-LCI.
Old 05-05-2013, 12:08 PM
  #424
ah_heng's Avatar
Ic... Thanks...
Old 05-05-2013, 04:09 PM
  #425
dbond's Avatar
to LCI guys missing some love (and the 'SPORT' indicator ) check your dashboard coding for
1. FDC_VERBAUT (address 00300005) - DYNAMIC DRIVING CONTROL (FDC) INSTALLED
2. FDC_ID_MONITOR (address 00300405) - IDENTIFICATION TIMEOUT FOR DYNAMIC DRIVING CONTROL (FDC)
Old 05-05-2013, 11:35 PM
  #426
Cockers's Avatar
My Ride: E60 530d
Thanks dbond. Looks like I have to buy the DCAN cable now and get programming
Old 05-06-2013, 10:22 AM
  #427
scottelzo's Avatar
My Ride: e60
ok well cockers beat me to it yes this works on lci i have done it on a e60 520d manual, no sport light up on dash but you can feel the difference in the steering straight away and on country roads so much more feel of the road the throttle response feels crisper too that little bit more responsive. just need to code the sport icon on dash now.
Old 05-06-2013, 11:03 AM
  #428
balbs's Avatar
My Ride: BMW
Originally Posted by stel_i79
i know..
can u please say yes
i will send u the conector..and make a cable for me as yours..so all ii will have to do is connect it to the sport button and to dtc in the mid dash
please..pretty please
i will "donate" some $
please give me your adress
I'm sorry. But I'm really worried about liability when doing stuff like that. Especially if it involves wiring.
Old 05-06-2013, 11:49 AM
  #429
paulie's Avatar
My Ride: E61 525i 2005, F11 528i 2012
Model Year: 2012
By the way, I found this screen shot from a Taiwanese site. It comes from a BMW Training Course that explains the Driving Dynamics Control (FDC) option:
Old 05-06-2013, 11:54 AM
  #430
540i's Avatar
Great find Paulie, I guess that answers a lot of questions.
Quick Reply: the way E60 was meant to be
