TV TUNER
I do have the pro nav, but without TV monitor.
Can I buy an original BMW TV video tuner, on eBay or at my dealer's (bmw part nr.6 935 980) ??
Do I need s.th. else to be able to watch TV in my car ? (antenna, wiring, ...) ??
My Ride: 2006 550i Titanium Silver, Black Dakota Leather, Aluminum Cube Trim, M Sport Pkg, Premium Pkg, Comfort Access, Head Up Display, Steptronic, Comfort Seats, Rear Heated Seats, Through Load, Park Distance Control, Navigation , HK Logic 7, etc
do a search. Several threads on this topic!
My Ride: E61 Titanium-Grey, Leather Dakota Black, 525d, Steptronic, Navi Prof & TV, Voice Input, Panorama ceiling, Xenon with dir, etc
Sorry, I don't find any other post.
The Ebay seller tells me I only need the antenna & the wiring (70 ?). Did somebody retrofit the TV founction ??
Someone has the TIS information (parts, drawings, ...) ??
My Ride: 530d Sport, Mystic Blue, Dakota leather,Professional Navigation,BMW Assist, Blue Tooth Prep +telematics, 6 Disc Changer, ML/Alloy 8jx18", Graduated Tint windscreen, Auto-Dim Int + folding Mirrors, Comfort Seats - Electric, Through Load system inc Ski Bag, Bi Xenon Headlights plus washer system, Automatic Air Conditioning-Advanced, HiFi Speaker System, Fitted Floor Mats, clear bra
I have looked at this on my TIS disk before, and I am pretty certain the car needs to be reprogrammed. I will check on my TIS disk tonight for any other requirements.
I've just heard on another forum that, if you retorfit the TV tuner the only thing you need is a cable from the TV tuner to the idrive system... The antenna is already in the "shark fin". After the install of the TV tuner, your BMW dealer must ad the feature TV, so the car knows it has the TV function.
Where is the TV tuner located ? Iceman? A picture of the tuner would be nice
There seem to be several issues. The TV control module is located in the left rear luggage compartment. If you remove the trim you will see where it is bolted, fixing the unit will require a new trim. The unit has two sockets, one for the two aerials located in rear windscreen. The second is for the power and feeds to the CCC, note information is relayed to the CCC by fibre optics. Unless these cables and sockets are already there it will be quite a bit of work, both laying the cables and getting access to the CCC.
Find attached a PDF that may be of use, or else it will put you off. Once it is all done you will require a reprogram.
E60tv.pdf
E60tv.pdf
Sorry about that first time I have posted pdf's didn't quite work.
It doesn't look as simple as connecting an aerial and a lead to the CCC
e60tvinstall.pdf
e60tvinstall2.pdf
e60tvinstall3.pdf
Aerials.pdf
e60tvinstall.pdf
e60tvinstall2.pdf
e60tvinstall3.pdf
Aerials.pdf
ucsbwsr
09-19-2015 10:58 AM
PelicanParts.com
07-23-2015 12:50 PM
PelicanParts.com
07-23-2015 12:41 PM
