Striking sound when moonroof closed from tilting up
My Ride: 06 530Xi w/ M-Sport Package
07 335i Cabriolet w/ M-Sport body kit
So I picked up the car. The repair record says:
"Rain gutter and rear of sunroof lid making contact. Modify rain gutter as per SI 54 15 05."
Work done under warranty. No further explanation from the service rep.
Anybody know what is in SI 54 15 05??
SIB 54 15 05
SUBJECT
Noise from Sunroof When Lowering from the Vent Position
MODEL
E60 (5 Series)
SITUATION
The customer may complain of a popping noise when closing the sunroof from the vent position.
CAUSE
Rear edge of the sunroof glass is colliding with the front edge of the water drain.
CORRECTION
File down the front edge of the water drain.
PROCEDURE
S5405U06
1. Remove the sunroof glass per Repair Instructions RA 54 12 115.
2. Apply a piece of masking tape (1) along the front edge of the water drain (2), 2 mm below the top edge.
Note: The tape should be approximately 800 mm in length and should be 25 mm (dimension A) from the end piece (3) on both sides of the water drain.
S5405U07
3. Using a file (4) shorten the front edge of the water drain (2) down to the piece of tape (1).
Note: Be careful not to cause any damage to the roof of the vehicle or the sunroof seal.
4. Smooth down the front edge of the water drain (2) with fine sandpaper.
5. Remove the masking tape from the water drain.
6. Remove the plastic splinters and dust produced from filing.
7. Grease the front edge of the water drain using Wurth Glide Grease, Article # 0893898.
8. Reinstall and adjust the sunroof glass per Repair Instructions RA 54 12 115.
9. Tighten the bolts to 5 Nm.
10. Refit the left and right side rubber gaiters.
11. Close the sunroof from vent position to ensure the noise has been is eliminated.
SUBJECT
MODEL
E60 (5 Series)
SITUATION
CAUSE
CORRECTION
PROCEDURE
S5405U06
S5405U07
My Ride: 2005 545i (SMG)
Titanium Gray
Black Interior, Anthracite Trim
M-tech kit
Sport Package
Premium Sound
Satellite Radio
Active Cruise
Comfort Seats
Navigation
Folding rear seats
Originally Posted by Iceman' post='326956' date='Aug 25 2006, 06:08 PM
That's gay.
![Devil](https://5series.net/forums/images/smilies/imported/devil.gif)
Yeah. Gayer than a pride parade in San Francisco.
My Ride: F02 LCI Individual
Model Year: 2013
Originally Posted by subterFUSE' post='327132' date='Aug 26 2006, 02:13 PM
Yeah. Gayer than a pride parade in San Francisco. ![Laughing](https://5series.net/forums/images/smilies/imported/laughing.gif)
I don't think that's possible.
![Nono](https://5series.net/forums/images/smilies/imported/nono.gif)
srogers535x
08-05-2015 08:48 AM
Ticomystico@gmail.com
07-10-2015 05:19 AM
jeffandjaimie
07-08-2015 05:48 PM
