Side View Mirror = no bumper view with reverse
My Ride: Close to ordering 2008 550i Sport Packg w/ sport auto tran.
Previous owner of 2000 328i and 2003 E39 M5
It worked fine but now it does not give me the curb view when in Reverse. Any way to reset this or fix?
On a side note, I pulled into a parking space and apparently went too far forward and when I back out, I ripped the front bumper of at the driver's side corner. It snaps back into place but the very last clip (closest to driver) is damaged. Im guessing this will cost me a pretty penny to have fixed. (entire bumper replaced)???
My Ride: E90 M3
Model Year: 2011
Have to ask the easy question first: Is the switch for the side mirrors set to the driver's side? If it is set to the passenger side then the dipping mirror is disabled.
As for the bumper, how bad does the bumper itself look? If it is only the clip it may not be too bad...
My Ride: F11 520d
Set the mirror adjustment switch to the left. Mirror won't move if the position is set for adjusting right mirror. Clever function, but caused some gray hairs for me also before it used search function in this forum.
My Ride: E90 M3
Model Year: 2011
Originally Posted by SSBaronM5' post='469246' date='Sep 13 2007, 03:30 PM
You cant even notice if you didnt know it happened. The problem is that I KNOW that it happened and it is a bit loose towards the end
Any luck on the mirror switch?
