SIB for spontaneous audio...
Old 11-10-2004, 10:04 AM
jmcaiado's Avatar
Originally Posted by mrbelk' date='Nov 10 2004, 02:59 PM
Well, like several of us, I have gone out to my car only to find it blasting the stereo.? It hasn't happened for a while, but I was poking around on the bmwtis.com site last night, and found this bulletin:
SUBJECT
Audio Stays On
MODEL
E60 (5 Series) with CCC, E63/E64 (6 Series)
From start of production up to October 18, 2004
SITUATION
Customer states the vehicle audio is coming on and stays on, even when the ignition is off and the car is locked.
CAUSE
Interference on open PIN 16 of the CCC main connector.
CORRECTION
On a customer complaint basis only, ground the open PIN 16 of the CCC main connector X13812.
Remove all necessary trim parts and the CCC. Refer to Repair Instruction RA 65 83 010 (Removing and installing/replacing Car Communication Computer).
Make up an additional ground wire (approx. 4 feet long) using 1.5 mm insulated wire.
Double crimp the female terminal P/N 61 13 1 387 144 on one side (ground splice) and the AMP female terminal P/N 61 13 8 364 838 (CCC connector) on the other side to the wire using the AMP crimping tool P/N 61 9 041 (Hand pliers for 2.5 mm contacts).
Connect the wire to the ground splice behind the glove box and run it to the CCC main connector PIN16 (this is an empty slot).
5. Before installing the wire to the CCC main connector X13812, remove the locking tab by sliding to the right as shown.
6. Install the ground wire terminal into the empty slot PIN16 on the CCC main connector, until the terminal is physically locked into position.
7. Slide the locking tab back into locking position.
8. Re-install the CCC and all removed trim parts. Refer to RA Repair Instruction 65 83 010 (Removing and installing/replacing Car Communication Computer).
PARTS INFORMATION
Part Number
Description
Quantity
61 13 8 364 838
AMP female terminal 1.0 ? 2.5 mm
Female terminal 1.5 ? 2.5 mm
There are some pictures, too, but they won't show up in this quoted text. I amdefinitely going to take the 5er in and get this fix performed.
-MrB
[snapback]54531[/snapback]
post by error...
Old 11-10-2004, 10:26 AM
Aaron's Avatar
My Ride: On Order: 2006 525i Alpine White Auburn Interior Premium Pkg Sport Pkg Cold Weather Pkg Xenons Sunshades Sat Radio Navigation
With an open connector pin, this is probably an electromagnetic interference issue and may explain why it is not being seen by everyone. While an EMC issue that turns the radio on is pretty bad, I don't know of too many manufacturers that would do a full recall for it. Hopefully none of you have had drained batteries from this, and for those that have seen this problem, I hope this truly fixes it.
Great find mrbelk!
Old 11-10-2004, 10:33 AM
zippers525's Avatar
I thought if you have advance aircon you also have a CCC. Im not sure though. This would mean all US spec cars have the CCC.
Old 11-10-2004, 10:38 AM
Wiu-Bimmer's Avatar
according to this, since I don't have NAV (That is, no CCC), I should never experience this, right?
Is anybody out there without NAV experiencing this?
Old 11-10-2004, 11:10 AM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
[snapback]54621[/snapback]
Advanced aircon does not require CCC. Nav is the key...
Old 11-10-2004, 06:09 PM
zippers525's Avatar
Ok. But isn't there a special computer for cars with Advanced aircon? If you have basic a/c you have differt computer i think. Maybe im wrong. I remember reading something somewhere a while ago.
JetBlack5OC
Lounge
12
05-20-2008 12:25 PM
cobradav
10-12-2007 06:38 PM
cobradav
10-09-2007 01:58 PM
cobradav
03-11-2006 07:37 AM
E60Speed
11-08-2005 11:19 AM
Quick Reply: SIB for spontaneous audio...
