Search results
Old Aug 20, 2012 | 04:17 AM
handyben's Avatar
Every time I searched for certain topic, the forum came back with the message: " Your search for the term '..........' returned xxx results", but instead of the results of the search I still see all the regular posts.
What did I do wrong and how do I get the search results?
Old Aug 20, 2012 | 04:29 AM
crypto's Avatar
To be honest I typically just use Google.
Search: site:5series.net + search term
Old Aug 20, 2012 | 04:33 AM
handyben's Avatar
Thanks Crypto for the suggestion. Anybody else has luck searching directly on this forum?
Old Aug 20, 2012 | 06:26 AM
crypto's Avatar
Also, I just tested the site's search and am not having issues. If I type in something and hit search it shows me all the threads with those terms. You have to read through them to find the match.
If you want to see the exact posts, use the detailed search function:
https://5series.net/forums/index.php...search_in=core
Click "Forums" instead of the default of "Help Files". This will bring up new options. From there you can select: Display results [x] As posts [ ] As a topic list
Old Aug 20, 2012 | 08:00 AM
tonyb635's Avatar
The problem with general searching is if you search "door panel removal" the search result will bring back every post that has any of these words and removal is very generic so the return will be very high. Google seems to work better.
tonyb635's Avatar
CHRGRS_BMW
38
Sep 1, 2016 09:39 AM
ripley
DIY: Do It Yourself
Sep 19, 2015 06:21 PM
ucsbwsr
Sep 19, 2015 10:58 AM
benski
F10 Discussion
Sep 16, 2015 07:10 PM
Bank$hot530
Sep 16, 2015 01:28 PM
