Oil Problem??
#21
Me too as it is a little embarrassing..., but it's normal and I just take mine home and do it there. It's just one qt, and the capacity is like seven. I believe the advisory tells you to add it soon...
#22
Ok, I normally get the light as I said ~ 2-3 thousand prior to the required service. Clearly I will change over to the mid point oil change and assume this will eliminate this issue for me. NOW MY QUESTION... Has anyone changed this sensor before? From reading all the comments, it might be something that I want to do in the future as preventative...
mantraguy
03-09-2015 02:56 AM
