The Official G-Meter Testing Thread
#161
My Ride: 2008 550I,manufactured 2-27-08,delivered 4-2-08.Platinum bronze,natural brown interior,light poplar trim,cold weather package,heated rear seats,HD radio
Originally Posted by jim_in_calgary' post='242840' date='Feb 19 2006, 04:10 PM
This is an interesting thread.
I have seen 1/4 mile times corrected for altitude. Is there any way to readout a corrected time/HP figure on these devices?
My location is 4000 ft above sea level, and I notice my cars have more pep when I travel to a sea level location.
I'd be interested in seeing the different readouts for the same car at sea-level and 4000 ft above if you could manage to get air temperatures in the same range.
#162
My Ride: 2006 550i Sport Package, Cold Weather Package, Premium Sound Package, Comfort Access, Xenon Headlights, Adaptive Headlight Control, Navigation System, Steptronic Transmission. Silver Gray Metallic with Gray Leather. Added Red rear reflectors. Swapped stock Style 124 wheels and Bridgestone run-flat tires for BMW Style 125 5-Double Spoke wheels, 8" x 19" front, 9.5" x 19" rear with Michelin Pilot Sport PS2 tires, 245/40YR-19 front and 275/30YR-19 rear.
Originally Posted by grogan545' post='242992' date='Feb 19 2006, 07:55 PM
Great to here from you jim.The chart that Znod refered you to says it all.At your altitude(4000') there is about a 5% correction in both time & speed in the 1/4 mile.In other words if you had a time of 14.00 secs in the 1/4 it would correct to 13.31 secs at sea level.Quite a difference.The NHRA monitors temp,pressure,humidity and comes up with an equivilent altitude.In other words if your actual altitude is 1500',but because of high temp and high humidity and low barometer reading your equivilent altitude may be 3500'.You would look at the chart and apply the factor for 3500' to your speed & times.
#163
Originally Posted by grogan545' post='242988' date='Feb 19 2006, 10:44 PM
Hi Znod,I owe you some answers from previous posts.
My best estimate for 0-90 &0-100 on my last 2 runs posted on 2-06-06 are:
................run 1.............run 2
0-90.........9.50..............9.65
0-100......11.55.............11.92
I can't believe we never discussed the altitude question before.Your altitude of 1500' certainly makes a difference in your times.The altitude here is about 300' so the difference is significant.I don't know if the factors gathered from the NHRA chart are true for the "time to Speed" figures,but the definitly are adversley affected by altitude.
I applied an extrapolated factor for 300' altitude to my best 0-60 run and I get .99664 X5.00=4.983.
Almost exactly what your best 0-60 after correction of 4.986.Very interesting.
Maybe your car was faster than mine before you went to 20.01.
Thanks.
I guess I never discussed altitude before just to keep things simple. But, when the issue came up today, I looked at the NHRA chart and realized that its adjustments would make a significant-looking difference in my times speeds. The way I understand the NHRA chart is that straight adjustment would yield times and speeds as though all other factors, such as temp, humidity, etc., are held constant. Thus, if we both adjusted using just this chart, then there still could be unaccounted for differences--e.g., temp, humidity, etc. To some extent, the unadjusted factors might or might not tend to cancel out. For example, your recent tests have been done when colder than here, but my humidiy is likely have been lower--thus, producing a cancellation effect.
But, you mention above that "the NHRA monitors temp,pressure,humidity and comes up with an equivilent altitude.In other words if your actual altitude is 1500',but because of high temp and high humidity and low barometer reading your equivilent altitude may be 3500'.You would look at the chart and apply the factor for 3500' to your speed & times." Is the "equivalent altitude" value, the same as what SMOKEmUP refers to as "density altitude?"
In this regard, where do you get the adjustments for equivalent altitudes?--at the dragstrip?--by paying the membership price at SMOKEmUP? And, once adjusted to sea level, what would the implicit values for the other factors, such as temp and humidity, be?--e.g., 60F and 20% humidity. If our other factors were similar to the NHRA standards for them, then it looks like we could avoid the equivalent altitude adjustments.
Here is another question that gets at what I am interested in knowing. Under what conditions, or sets of conditions, would the NHRA indicate that no adjustment to equivalent altitude is needed? Also, I know at least one big three US auto mag makes adjustments. I am going to try to figure out what they all do--probably with no luck on all though.
I don't guess the NHRA has an octane adjustment too, huh?
#164
Originally Posted by E60VTA' post='243003' date='Feb 20 2006, 12:16 AM
So, ZNOD needs to go back and review historical data for barometric pressure on the days he ran previous tests. Maybe the speed anomolies are barometric pressure related and have nothing to do with CIP change. Learning could still be a factor.
#165
g-man and all:
I registered for SMOKEmUP and paid for 3 mos. of calculator usage. I am getting my answers now. So, far I have been able to find hourly weather data for Phoenix for today. Using the 3:00 a.m. values, which should be similar for the whole month, my density altitude would be about 1429 rather than 1500. I have not been able to find hourly data for, say, the last month, but I imagine I will find it soon. Still researching, but this is my busy work day.
#166
Originally Posted by Znod' post='243009' date='Feb 20 2006, 12:43 AM
Hi g-man:
Thanks.
Thanks.
You are correct with your analysis of the "equivilent" altitude.Your actual altitude has a minimal input as to your times.When I was at the drag strip last July the "equivilent" altitude was 3750" even though the actual altitude was only about 300'.For now I am going to ignore corrections until i can verify what actual conditions are while testing.All I can say now is it is cold with low humidity and an average barometer reading.
NOW FOR THE BIG NEWS.I HAVE DONE IT ZMAN CHECK OUT THESE NUMBERS !!!!!!!!!
...........................run 1(N)...............run 2(S)...............ave
0-10..................... .27....................... .30...................... .285
0-20..................... .90....................... .95...................... .925
0-30..................... 1.58..................... 1.62.................... 1.60
0-40..................... 2.68..................... 2.75.................... 2.715
0-50..................... 3.65..................... 3.75.................... 3.70
0-60..................... 4.80..................... 4.98.................... 4.89
0-70..................... 6.32..................... 6.53.................... 6.425
0-80..................... 7.85..................... 8.07.................... 7.96
0-90..................... 9.50..................... 9.83.................... 9.665
1/8 time................8.60..................... 8.70..................... 8.65
1/8 speed............ 83.1..................... 82.2......................82.65
60'...................... 1.92..................... 1.97....................... 1.945
330'.................... 5.60..................... 5.67....................... 5.635
1000'.................. 11.13................... 11.30...................... 11.215
HP..................... 368 @ 57 mph....... 360 @ 57 mph......... 364 @ 57 mph
1/4(grogans form) 13.26.................... 13.42..................... 13.34
estimated spd 1/4. 105.5................... 104........................ 104.75
Temp was 26F,humidity about 35%.All runs with controls on and in D.Shift points appear to be at 6500 rpm
I am now thoroughly convinced of my method I believe I can get the "super start" 2 out of 3 tries.I really believe you should work on my method .I know it is discouraging when it doesn't work but with patience I think it will work for you.The most important thing is to go to full throttle in a "SLOW"manner.This is harder than it sounds because the tendency is to mash the throttle when you let off the brake.This will cause the controls to overreact and cause the car to bog and hesitate(5.4 0-60 for me).
#167
You are so correct about applying the throttle.....I really struggle with this and I tend to mash it and then I get wheel spin an there goes the run.....although I do think it's a little harder with a manual, but once perfected I hope to get times similar to yours.....
Cheers,
#168
Originally Posted by grogan545' post='243241' date='Feb 20 2006, 02:24 PM
Hi Znod
I will try your method--first in DS I suppose. I doubt that I will improve my actual times anymore without colder weather. If the weather gets colder, then I probably will do what I have been doing or mix things up. I suspect that I will start adjusting for weather and altitude since I want my runs to be comparable. Otherwise, when summer arrives, there would be no point to testing in Phoenix at all.
And, again, congratulations on doing what no one, as far as we know, has done.
Oh, and did you see my post #165? And, if you can get approximate dew point and barometric pressure (i.e., altimeter setting), then please give them to me along with their units of measure.
#169
They are pretty impressive
#170
Originally Posted by Bokke' post='243299' date='Feb 20 2006, 04:08 PM
Perhaps we should have a separate "best results" thread, so that everyone will see his numbers without going all the way to page 12.
