Sponsored by:
Sponsored by:
OBD2 Memory Saver Question
Old 05-30-2019, 07:44 PM
donpb's Avatar
My Ride: '06 530i N52
Question OBD2 Memory Saver Question
After changing my battery and then getting a bunch of bogus notifications, my indy mechanic informs me that I needed to keep power while changing the battery. I'm like uh well how do you do that? He said he uses some gadget connected to the obd2 port.
I found out its called a memory saver and there's tons of different types.
My question is, isn't there other ways to do this like connecting a battery charger to the front battery terminals? Also, I see the ones that connect to the lighter port but how in the heck would that work when the lighter port is off? Yeah I long since noticed my lighter port shuts off after a bit. Is anyone else using a memory saver or what technique do you use? Thanks.
Old 05-31-2019, 08:09 AM
kd7iwp's Avatar
My Ride: 2009 535xi Touring 6MT, 2001 325i 5MT
Engine: N54, M54
You're correct that the lighter turns off with the ignition so that would not work. I've never bothered to keep anything like this running. I don't see why your idea of putting a charger on the front terminals wouldn't work. I personally wouldn't use the OBD2 port because I don't think it would be able to handle much current and if the fuel pump tried to prime, or lights turned on, etc. while you disconnected the battery it might try to pull too much current through there. I also personally wouldn't bother as the only thing that seems to happen to me when I disconnect the battery is I have to set the time, and occasionally I need to turn the steering wheel lock to lock to reinitialize the steering angle sensor.
Old 05-31-2019, 08:14 AM
FormerE30Owner's Avatar
My Ride: 2005 545i, premium package, 6sp manual, cold package, navigation package.
Model Year: 2005
Engine: N62
I just connect a booster battery to the front terminals. I don't think that a battery charger would suffice.
Old 05-31-2019, 08:37 AM
donpb's Avatar
That sounds like a good idea.
Old 05-31-2019, 08:40 AM
donpb's Avatar
Normally nothing happens but this time a lot of notifications sprang up that I cannot clear and so I have to pay my mechanic to clear them. That's when he told me I needed to keep power to the car when disconnecting the battery.
Old 06-03-2019, 12:31 PM
cmyachtie's Avatar
My Ride: 2004 545i+BT+AUX+Coding
Engine: N62
sounds like BS to me as I have one of those memory savers and never used it as despite having had battery disconnected for days several times never had an issue with either radio nor seat memory being lost.
Just get an AFS AND DSC code upon startup and after initializing the steering, All is well again....
Old 06-03-2019, 01:30 PM
donpb's Avatar
I stated that nothing usually happens like you say but not this time.
Old 06-04-2019, 07:00 AM
rice_rocket88's Avatar
My Ride: 2008 535xi
Engine: n54
I have done it before with a battery tender attached... however, I have had the instance where changing it and a battery tender was not available, still no problems. It is possible that you could have new codes thrown after it, but once you clear it you're good to go. I'm not sure why/how there is/was residual electronics, but the test was looking at the clock, after swapping the battery without any aux power the time stayed consistent so.. there you go.
doughboy540
03-12-2014 12:15 PM
sirch
05-07-2008 11:52 AM
marklp
01-18-2007 01:58 PM
Member545
08-19-2004 08:03 AM
Quick Reply: OBD2 Memory Saver Question
