Not starting after engine is warm
My Ride: E60 2008 535i, all factory options, no mods
My ‘08 535i will not start after the engine is warm. They car starts perfectly fine when the engine is cold. The starter has no trouble turning over the engine when it engages. The battery is good and tested.
My Ride: 535xi hud night vision
Model Year: 08
Has the starter been replaced? If so it may be missing a heat shield. It may also be a bad Crank Sensor.
If you feel so inclined you can try jumping the starter while hot to confirm if it is the issue.
So when hot you hit the button and nothing? xray pointed to possibly a missing heat shield. I'd begin by seeing if you get 12V to the solenoid whilst attempting the hot start. If no 12V, problem is elsewhere.
BallyM5
DIY: Do It Yourself
06-07-2011 02:23 AM
aretardedorange
10-15-2010 08:38 PM
