Not starting after engine is warm
My ‘08 535i will not start after the engine is warm. They car starts perfectly fine when the engine is cold. The starter has no trouble turning over the engine when it engages. The battery is good and tested.
When you say it doesn’t start can you give other symptoms? Is it cranking or not. Any noises? Lights? Codes?
No codes being read, no warning lights, and the only noise is the water pump.
Originally Posted by Superbear321
(Post 1600937)
Yes it runs fun once it starts. But the starter is not doing anything.
(Post 1600949)
Has the starter been replaced? If so it may be missing a heat shield. It may also be a bad Crank Sensor. If you feel so inclined you can try jumping the starter while hot to confirm if it is the issue. |
So when hot you hit the button and nothing? xray pointed to possibly a missing heat shield. I'd begin by seeing if you get 12V to the solenoid whilst attempting the hot start. If no 12V, problem is elsewhere.
